As above, installed between the mains and a newish electric shower, shower flow stops when weather gets warm or during the day as it heats up, its a dedicated supply to the shower.
Looks a bit special. Dare to take off the caps (maybe noting position) to see what's under there?
Says 'wetsco' - what's the other writing say on there? Can't see anything here, but I didn't spend much time looking:
https://shop.westco.co.uk/
Best guess Google came up with was a baby manifold, but that doesn't make any sense as the dimensions of the two take-offs are different.
That’s odd. Whatever it is it sounds broke! Try removing it and plumbing straight through
@Nickfromwales any idea mate?
Not mine but definitely seems to be some form of flow regulator based on the incoming water temperature but why it is installed on the supply to a electric shower is very strange so will suggest just removing it.
I recognise it, ie have seen one before.
I think it may be a backflow prevention valve, fitted just before an outside tap.
It is so that a hose immersed in a bucket cannot provide a flow back into the mains system in the case of reverse pressure.
