Davecara Posted July 10, 2024 Posted July 10, 2024 I'm in the process of buying a house and its got a space the perfect size for a garage for me to keep my bikes and wotnot in while having minimal impact on the size of the garden for the small folk. Only issue is that the space is between the house and the road. Its a corner plot, the road up the side is a weird setup as its up the back of the houses it serves, they're all back to front if that makes sense? 60's council houses I guess. The other side of the road next to me is a day nursery with a 7 foot black fence all the way around I cant make head nor tail of the PD regs and I'm fairly certain now that i will need full planning permission. Is there a way of getting the nod without spending out for proper drawings? Like an 'agreement in principle' per se? Then if the planner agree in principle then I go ahead and get proper drawings and calcs for drainage off the roof and such. I don't want the expense of getting proper drawings done if its going to be chucked straight out if I can help it Thanks for any tips/pointers/advice/ribbing etc Existing: What I want to build: (excuse MS Paint drawings!) Plan view
joe90 Posted July 10, 2024 Posted July 10, 2024 No reason why you can’t do your own drawings, it’s not rocket science. If it’s less than 30 sq m then building regs don’t apply. Some bedtime reading fir you. https://ecab.planningportal.co.uk/uploads/1app/maps_plans_and_planning_apps.pdf 1
BotusBuild Posted July 10, 2024 Posted July 10, 2024 Does you LPA (Local Planning Authority) provide a"pre-planning advice" service? It may be chargeable.
joe90 Posted July 10, 2024 Posted July 10, 2024 Also you mention back to front houses (we have some outside Bristol) photos of garages etc on the road may help your case as not pretty front gardens.
DevilDamo Posted July 10, 2024 Posted July 10, 2024 You would require and should not require Building Regulations. 1
joe90 Posted July 10, 2024 Posted July 10, 2024 45 minutes ago, DevilDamo said: You would require and should not require Building Regulations. Eh?
ProDave Posted July 10, 2024 Posted July 10, 2024 It will need planning permission, but the fact you already have a tall brick wall on the boundary should make that much easier. 1
DevilDamo Posted July 10, 2024 Posted July 10, 2024 4 hours ago, joe90 said: Eh? Apologies. I’m quite sure I wrote it properly. Will try again… You would require Planning and should not require Building Regulations. 1
Davecara Posted July 11, 2024 Author Posted July 11, 2024 Thanks, wasn't sure about regs, as it will be under 30 sqm but I didn't know if it being attached to the property would have any bearing on it. As for planning: I've sent a speculative email to the council pre planning team (Which I didnt know was a thing!) so hopefully they'll give an indication of what they want from me
DevilDamo Posted July 11, 2024 Posted July 11, 2024 @Davecara A Householder Planning application including a location plan, block/site plan, existing and proposed plans and elevations and any other requirements to meet your LPA’s validation list.
kandgmitchell Posted July 11, 2024 Posted July 11, 2024 It'll only be exempt Building Regulations if detached. Do the plans for planning approval yourself - it'll probably cost you for pre-application advice (although some Councils don't charge householders) and almost certainly they'll ask for the sort of drawings you'll need for an application anyway. 1
