What to do with MVHR for final airtest
searched but couldn’t find an answer to this
Got our final air test next week and just wondering what the best strategy is re MVHR.  For Earlier Test (0.42) it wasn’t installed so we just taped up the penetrations.
For this test can we just seal the outside ducts with an airtight membrane and tape?
We had an air test done pre plasterboard, fixed all leaks, then on the final air test the guy just put tape on the room terminals, test was no better than the first test. So don't do that. Do as others have said and isolate the mvhr from the outside world.
no ceilings ?
43 minutes ago, Dave Jones said:
you said air test pre-plasterboard ?
Would be hard with ceilings open to trusses no ?
It was just ready to plasterboard, all insulation, vapour and airtightness done, but with access to fix stuff. So service void battens on walls and ceilings etc. Holes through wall for mvhr were blanked off at the wall.
Thanks all.
we also did a pre plasterboard (bare shell) 0.9, then a pre second fix test 0.42
We followed the advice re sealing the external MVHR ducts, it worked well enough, final result 0.47 ACPH.  Electrician had to re feed wires through a duct during second fix due to a fault so looks like we didn’t seal it as well as we’d previously.
  • 1 month later...
Hi all - we have powder coated external MVHR vents in rendered walls. Did anyone find a good way to tape up the vents without pulling all the paint off? We've already had a bit of paint come off (mastic man on a ladder!). Thanks
If masking tape is pulling off the coating, they were badly done. I would strip the coating off and redo with a decent primer and top coat.
It may be easiest to take the inlet and outlet off the MVHR unit and bag and tape the ends there.
