Barney12 Posted October 8, 2017 Posted October 8, 2017 Due to a "design issue" (AKA Cock Up!) I've ended up with a MHRV extract plenum in the shower area. From what I've read this is against best advise. Assume this is due to the levels of humidity in the ducting?? Is it an absolute "no" or in reality is it not too much of an issue. Moving it is not an option now but I could change the bathroom design but it would be a considerable compromise. TIA
ProDave Posted October 8, 2017 Posted October 8, 2017 Some mvhr units have a max limit on humidity, I seem to recall 80% for my unit. However, even if the humidity in the shower is 100%, it will be extracting from 4 other places a well. So the RH of what reaches the mvhr unit will be "diluted". Unless I am miss understanding that point, it would only be an issue if both showers were in use together, someone had lots of pans boiling away in the kitchen, and the utility room was full of wet washing all at the same time.
ragg987 Posted October 8, 2017 Posted October 8, 2017 If you take a hot shower, the volume in the room is probably approaching 90 or 100% humidity regardless of location of extract. I am guessing any issue might be related to water spraying getting sucked in. If the extract is quite high relative to shower area might be ok. Also, is your shower cubicle sealed on all sides? This might create a flow restriction?
Barney12 Posted October 8, 2017 Author Posted October 8, 2017 3 hours ago, ragg987 said: If you take a hot shower, the volume in the room is probably approaching 90 or 100% humidity regardless of location of extract. I am guessing any issue might be related to water spraying getting sucked in. If the extract is quite high relative to shower area might be ok. Also, is your shower cubicle sealed on all sides? This might create a flow restriction? No it's will be in a corner. Only one glass screen, the other side open to the room. So hopefully no issues with flow.
Barney12 Posted October 8, 2017 Author Posted October 8, 2017 (edited) 6 hours ago, ProDave said: Some mvhr units have a max limit on humidity, I seem to recall 80% for my unit. However, even if the humidity in the shower is 100%, it will be extracting from 4 other places a well. So the RH of what reaches the mvhr unit will be "diluted". Unless I am miss understanding that point, it would only be an issue if both showers were in use together, someone had lots of pans boiling away in the kitchen, and the utility room was full of wet washing all at the same time. That makes sense. I'll find out what the max is on my Airflow Androit. Edited October 8, 2017 by Barney12 Typo
Stones Posted October 8, 2017 Posted October 8, 2017 The extract vents in both of our bathrooms are located over the shower enclosures. This was intentional and something I have done with every build except one, where the extract for one shower was outwith the enclosure. That particular enclosure suffered from peeling paint on the ceiling, whereas none of the others ever did. It may not of course be connected, but I certainly attributed the problem to the fact that there wasn't an immediate extraction point over the shower.
Barney12 Posted October 8, 2017 Author Posted October 8, 2017 (edited) 10 minutes ago, Stones said: The extract vents in both of our bathrooms are located over the shower enclosures. This was intentional and something I have done with every build except one, where the extract for one shower was outwith the enclosure. That particular enclosure suffered from peeling paint on the ceiling, whereas none of the others ever did. It may not of course be connected, but I certainly attributed the problem to the fact that there wasn't an immediate extraction point over the shower. Ive always done the same when using a standard extract vent to the outside. This is my first time with MHRV so I'm doing that typical self build thing by reading everything and following the rules. Which then follows with worrying about every detail Edited October 8, 2017 by Barney12
Stones Posted October 8, 2017 Posted October 8, 2017 We're on house no 4 with MVHR, so have learned (I like to think) from experience what works and what doesn't.
Gone West Posted October 9, 2017 Posted October 9, 2017 I have an extract in my wetroom which is near the shower. Can't be anything but near because it's a small room. I wouldn't worry.
