Hi all I have a house with two arched glass panels above the patio doors at the back built in the 90’s, brick outer wall with cavity and thermalite inner. The exterior of the property is fully rendered.
I want to square off the arch in order to fit bifold doors.
I am considering using a catnic installed from inside then bricking up into the arch.
I have explored the construction at present and the external arch is constructed with soldiers with no lintel.
it is a gentle arch spanning just over 3m.
obviously the arch is self supporting therefore I don’t see the need to disturb it but just use the catnic to square things off. In essence the catnic would add more support if anything.
Is my plan acceptable any advice would be greatly appreciated.
Your infill brickwork is all that’s supported by the catnic and minimal in weight. You just need to cut it into the existing brickwork at each end (which might compromise the arch stability during fitting !!!!
-sucks through teeth----- twitches in discomfort -------inner engineering purist sobs-----------!!!!!
The arch is such an elegant solution. In fact a beautiful one in my mind. Seems a shame to hide it.
On a more pragmatic note bi-folds are notoriously poor for airtighess. I think @nod has some in his last house that were quite draughty.
Would you consider a set of wider french doors? They'd be cheaper to boot.
12 hours ago, Marko127 said:
Here’s the picture.  Thanks everyone
I really like the look. Shame it's going to be replaced with bifolds. You might regret it afterwards, but we all have our likes and dislikes.
We’ve gone for three sets of sliders Nice easy to fit and much more airtight than bifolds
The bifolds that I fitted on are previous build are pretty good But far from airtight I think it’s more in the design
The manufacturer sent us larger seals
Which seemed to help but made them hard to open and shut
Agreed. Why not leave this all alone and just infill the gap?
Can of worms here afaic, and if I was asked to alter it I’d put-log it, remove the arch to get proper access for installing the beams, then brick fill back in accordingly. I’d never disturb those ends, there’s a lot of differing forces at play there.
There's a reasonable chance there's an arched lintel or tension strap in place. I should get a complete understanding of the existing structure first, that will probably need some intrusive investigations and a visit from a SE (or do you have construction drawings?). I concur with there's a potential can of worms that needs to be dodged.
I'd then have detailed discussion with a window supplier. Potentially they could support a aluminium infill panel or glazed infill. The extra cost of this would be somewhat offset by not messing with lintels.
Simple fix is to remove the arch and put in a flat lintel but it would be lost a nice feature.
11 minutes ago, George said:
Simple fix is
To get the door manufacturers to supply an infill panel. I like arches (I had them on all my windows) 😎
  • Sad 1
However I had some made for my build in oak,  rubber seals not brushes and were airtight during the test, it is usually the brush type of seal that’s bad on some.
Hi all the picture relates to how it looked before rendering.
My wife has disliked the arches since we moved in 6 years ago so they are definitely going!!
As I said it’s just squaring the arches off I am after advice with.
At the moment I am thinking the addition of a catnic at the base of the arch is probably the best solution.
I will install from the inside so as not to interfere with the arch itself for obvious reasons.
I will then infill with block on both sides and render the outside so nothing will be visible once the work is done
I can't see a way to get a lintel where it needs to be without destabilising the arch in the process.
Needle beams and props I think.
You could just build a lightweight timber frame to support render carrier boards, like Bluclad.  You could screw into the underside of the arch for support.  You can then mesh / render the whole thing.
This would be the least expensive and least intrusive answer IMO
