steveoelliott Posted February 24, 2024 Share Posted February 24, 2024 Hi, As I need to purchase two new taps for our en suite, I've noticed that almost all taps now come with flexi tails as standard. I've read some horror stories about these bursting / leaking so would prefer rigid fixings like the existing ones they are replacing. I'm looking to purchase this tap: Blitz Basin Mixer Chrome | Bathroom Taps | Bristan - https://www.bristan.com/products/bathroom-taps?code=btz%20bas%20c Am I correct in assuming, I can just buy these m10 copper tails as a solution: https://www.wolseley.co.uk/product/bristan-m10x-copper-tails-265mm-pd77157-44/ I contacted Bristan and asked the same question and their response was to use the supplied flexi, they have a 10 year guarantee and fitting copper tails would void warranty etc. The thing is whilst they might have a 10 year guarantee, they aren't going to deal with the damage caused if one of those flexi's bursts! It's irritating because almost all taps now come with flexi hoses as standard and I understand flexi hose is the standard for toilet cisterns now too. I'd just rather have rigid. Thanks in advance... Link to comment Share on other sites More sharing options...
JohnMo Posted February 24, 2024 Share Posted February 24, 2024 Never had an issue with Flexi hoses. The only way they burst is if you get them all twisted and buckled. If flexible hoses are bad, I pity every car on the road as they have tonnes of them, for fuel, brakes, and air. Stop listening to plonkers on social media, that possibly don't know any better, and possibly caused there own issues in the first place. 1 Link to comment Share on other sites More sharing options...
steveoelliott Posted February 24, 2024 Author Share Posted February 24, 2024 8 minutes ago, JohnMo said: Never had an issue with Flexi hoses. The only way they burst is if you get them all twisted and buckled. If flexible hoses are bad, I pity every car on the road as they have tonnes of them, for fuel, brakes, and air. Stop listening to plonkers on social media, that possibly don't know any better, and possibly caused there own issues in the first place. The ones we do have elsewhere I've looked at and their condition seems fine and they aren't under any visible stress etc. Link to comment Share on other sites More sharing options...
joe90 Posted February 24, 2024 Share Posted February 24, 2024 In all my years fitting kitchens and bathrooms I have only had one let go and that had been fitted badly (not by me). Not all flexi,s are equal, if they are willing to give a 10 year guarantee I believe they will have sourced a decent make. 2 Link to comment Share on other sites More sharing options...
steveoelliott Posted February 24, 2024 Author Share Posted February 24, 2024 53 minutes ago, joe90 said: In all my years fitting kitchens and bathrooms I have only had one let go and that had been fitted badly (not by me). Not all flexi,s are equal, if they are willing to give a 10 year guarantee I believe they will have sourced a decent make. That gives me a further degree of reassurance. Thank you. 1 Link to comment Share on other sites More sharing options...
Mike Posted February 24, 2024 Share Posted February 24, 2024 11 hours ago, JohnMo said: The only way they burst is if you get them all twisted and buckled That's a common problem, particularly with DIY, but it's certainly not the only way. It's a real issue: 11 hours ago, steveoelliott said: Am I correct in assuming, I can just buy these m10 copper tails as a solution Yes, unless they take M8 tails, but I guess you've asked that. I'd be changing them. 2 Link to comment Share on other sites More sharing options...
Conor Posted February 24, 2024 Share Posted February 24, 2024 Just don't over twist or kink them. Or over tighten. They usually have rubber o-rings and don't need much more than hand tight. 2 Link to comment Share on other sites More sharing options...
JohnMo Posted February 24, 2024 Share Posted February 24, 2024 1 hour ago, Mike said: That's a common problem, particularly with DIY, Perhaps those people shouldn't be doing DIY, they should get the plumber in. Or possibly read the instructions that tell how to install a hose without kinking and twisting it. 1 Link to comment Share on other sites More sharing options...
steveoelliott Posted February 24, 2024 Author Share Posted February 24, 2024 (edited) To be honest, anything involving mains pressure water, I get a plumber in for. It looks and for the most part should be easier enough for a competent DIYer but I like the comfort in using a plumber I trust. Plus the fact if it does go wrong, I have somebody to blame (shout at metaphorically) and put right! With water so much damage can be caused by a simple novice mistake. Edited February 24, 2024 by steveoelliott Link to comment Share on other sites More sharing options...
sharpener Posted February 25, 2024 Share Posted February 25, 2024 Don't personally like flexis much but have had no problems where they were necessary. They have been used on the Continent for decades. A lot of satisfaction to be had from DIY, you can take your time over it and choose your fittings not rely on what is in the back of someone's van, often the result is to a higher standard than a professional would have left. Also you end up with a much better knowledge which helps enormously with fault-finding, and you are not paying someone for the time taken to trace and understand the plumbing in your own house. 1 Link to comment Share on other sites More sharing options...
Pocster Posted February 25, 2024 Share Posted February 25, 2024 Flexi’s can fail for no obvious reason . Agree some must be better than others . Now ( after experience ) I only use flexi where I have too - do a visual inspection every 12 months for any sign of decay / leak . My new kitchen I installed copper rod fittings . I feel happier about that . 1 Link to comment Share on other sites More sharing options...
