Garden outbuilding joists
Andrew1981
I think you will find it is a bit more complicated than just asking the question.
A lot more details is needed.
But here is some light reading
https://www.structuralbasics.com/flat-roof-beam-design/
https://www.structuralbasics.com/timber-truss-roof/
https://www.structuralbasics.com/rafter-roof-design/
https://www.structuralbasics.com/purlin-roof-design/
Edited by SteamyTea
That's going to be rather from first principles isn't it?
Ie not easy-to -use tables.
Somewhere I've got a book full of tables that takes all the science out of it.  Such must be findable online I'd think.
26 minutes ago, SteamyTea said:
What is it called,
If I could find it I would be able to tell you.
Section tables for timber joists?  Searching for that I found this table...probably the same as the NI one. https://www.timberbeamcalculator.co.uk/en-gb/span-table/floor-joists?load=1.5&class=C24
and in nhbc https://nhbc-standards.co.uk/2018/6-superstructure-excluding-roofs/6-4-timber-and-concrete-upper-floors/6-4-8-timber-joist-spans/
