Does brick plinth really add expense?
flanagaj
The granted PP on the plot we are purchasing has oak cladding with a lower brick section with no plinth. I personally, much prefer the plinth as shown in the image below, but conscious of a finite budget I have a feeling that this option adds a lot of expense?  The brick plinths seem quite expensive.
Border Oak - Weatherboarded barn style home under construction. | Oak ...
Plinth bricks can be expensive.  From memory ours added >£4k plus labour, but it depends how many corners you have, and whether there are 1 course or two.  A cheaper alternative for us would have been to use some non-matching engineering plinth bricks,  but I didn't like the contrast.  It does give the house some additional character and a traditional look though.
i’m not sure what you mean here - bricks are planned already up to ground level or 150mm above, and you want more courses?
The granted PP does not have a plinth
It must have something from the ground up to the timber level. If not shown on the planning drawing then that is a technical oversight. The planners will accept a clarification.
Bricks are relatively expensive but are replacing something else....blocks or concrete usually.
