Thorfun Posted January 31, 2024 Posted January 31, 2024 Anyone used FC1? https://www.builderdepot.co.uk/c-tec-fc1-ultimate-all-in-one-filler-caulk-white-310ml https://www.madeinbritain.org/news/ct1-introduces-fc1-the-ultimate-filler-caulk-combination-for-professional-applications-dec-2023
SteamyTea Posted February 1, 2024 Posted February 1, 2024 No idea about how good it is. Is there anything that makes you think it will be better than the £1/tube ones?
Thorfun Posted February 1, 2024 Author Posted February 1, 2024 2 hours ago, SteamyTea said: No idea about how good it is. Is there anything that makes you think it will be better than the £1/tube ones? it says it's paintable whereas i didn't think standard caulk was paintable? i wonder how much that is worth. there are other filling caulks around that are more expensive that FC1 too.
joe90 Posted February 1, 2024 Posted February 1, 2024 Yes all caulk should be paintable I used https://www.screwfix.com/p/no-nonsense-decorators-caulk-white-310ml/57568 2 1
Thorfun Posted February 1, 2024 Author Posted February 1, 2024 17 minutes ago, joe90 said: Yes all caulk should be paintable I used https://www.screwfix.com/p/no-nonsense-decorators-caulk-white-310ml/57568 nice one. thanks. here ends my research in to caulk! 🤣
JohnMo Posted February 1, 2024 Posted February 1, 2024 As it says in the video, normal caulk shrinks. So you end up with cracks every couple of years. Then you need to think about painting again. Bigger the gap the more it shrinks.
Thorfun Posted February 1, 2024 Author Posted February 1, 2024 5 minutes ago, JohnMo said: As it says in the video, normal caulk shrinks. So you end up with cracks every couple of years. Then you need to think about painting again. Bigger the gap the more it shrinks. so there is benefit in the FC1? or is that just marketing BS?
JohnMo Posted February 1, 2024 Posted February 1, 2024 16 minutes ago, Thorfun said: so there is benefit in the FC1? or is that just marketing BS? Depends if it doesn't or does shrink really.
SteamyTea Posted February 1, 2024 Posted February 1, 2024 Most caulks are a water based acrylic. They have different amounts of inert fillers, the more filler, or the larger the particles, the less shrinkage. If you really want to fill something permanently, see about using an epoxy, because they generally have very small quantities of volatile (at normal temperatures), and the polymer cross linking is more thorough, they tend to stay the same volume. If you want some gap fill, then polyurethane is the material of choice, but they will, after time, shrink (just look at a car dashboard or furniture cushion).
joe90 Posted February 1, 2024 Posted February 1, 2024 1 hour ago, SteamyTea said: If you really want to fill something permanently, see about using an epoxy, However caulk can remain flexible and wood (skirting etc) shrinks so cracking would still be a potential problem with epoxy 🤷♂️. CT1 has such a good reputation and £4 instead of £1 is not going to break the bank in the scheme of things. 1
SteamyTea Posted February 1, 2024 Posted February 1, 2024 19 minutes ago, joe90 said: CT1 I seem to remember it is paintable as well. @Pocster is the CT1 man, we all told him that it will fix everything. As I drove on the M25 yesterday, between the M40 and M4, there is a very large electronic sign advertising CT1. Must be there to remind all the Boing engineers it is used to stick the doors on. 1
Thorfun Posted February 1, 2024 Author Posted February 1, 2024 1 hour ago, joe90 said: CT1 has such a good reputation and £4 instead of £1 is not going to break the bank in the scheme of things. this is what i was thinking too
