JustStartingOut Posted January 26, 2024 Share Posted January 26, 2024 I'm painting the final coats on plastered walls and ceilling and having difficulty getting straight lines. What type of brush should I use and are there any tools recommended to get a clean finish between wall and ceilling. I have tried masking tape but as the ceilling is slopping at 40 degrees they are not perfectly straight between wall and ceilling. Link to comment Share on other sites More sharing options...
bassanclan Posted January 26, 2024 Share Posted January 26, 2024 2.5" synthetic brush. Hold it sideways. Watch some YouTube etcvideos of cutting in. Masking tape is rarely the answer Link to comment Share on other sites More sharing options...
ProDave Posted January 26, 2024 Share Posted January 26, 2024 A lot depends on the quality of the corner. Nice smooth crisp plastering with a perfectly smooth, straight transition = easy. Old knackered ceiling with lots of patched up cracks and a corner that if far from smooth and straight = very hard to get it looking right. Link to comment Share on other sites More sharing options...
twice round the block Posted January 26, 2024 Share Posted January 26, 2024 You can buy cutting-in brushes they have a 30 angle on the bristles or use a quality 2 inch brush with long bristles so you can load lot's of paint up and use a steady hand and work around the room anticlockwise if your right handed..... Do not buy cheap brushes or rollers or paints, it's false economy. Link to comment Share on other sites More sharing options...
Russdl Posted January 26, 2024 Share Posted January 26, 2024 +1 to all that advice above but especially the YouTube tutorial stuff. Also bear in mind that when you’re up close and painting it may look a bit shabby however when you get off the steps and stand back it may not be quite so bad. Link to comment Share on other sites More sharing options...
ToughButterCup Posted January 27, 2024 Share Posted January 27, 2024 Loads of help on YT and Instagram. Link to comment Share on other sites More sharing options...
