NIreland Posted September 18, 2017 Posted September 18, 2017 Having over spent on unexpected items we've had to put our plans for a garage to a halt. We planned to put the boiler in garage but without the garage where to we locate the boiler, inside or outside? Ufh downstairs and rads upstairs. Any thoughts would be appreciated
nod Posted September 18, 2017 Posted September 18, 2017 We've UFH and rads upstairs also our garage is to far from the house to site a boiler So we have decided to locate the boiler in the utility room with a hot water storage tank below hope this is of help Gary 1
Nickfromwales Posted September 19, 2017 Posted September 19, 2017 2 hours ago, NIreland said: Having over spent on unexpected items we've had to put our plans for a garage to a halt. We planned to put the boiler in garage but without the garage where to we locate the boiler, inside or outside? Ufh downstairs and rads upstairs. Any thoughts would be appreciated Gas or oil?
dpmiller Posted September 19, 2017 Posted September 19, 2017 presuming oil... do you want to build an external "boilerhouse" or would you mind a fabricated unit? Or have you somewhere inside where an oily smell wouldn't be a problem? I put a Turkington condensing jobbie in the current place and it's very neat. the Combi version is a touch bigger but it's still quite a small box. Great boiler, well impressed. http://www.turco.co.uk/countryman 1
ProDave Posted September 19, 2017 Posted September 19, 2017 A properly installed oil boiler will NOT produce any smells inside the house. In our old house it i in the utility room without issue. 1
Nickfromwales Posted September 19, 2017 Posted September 19, 2017 Stinks a bit when servicing it properly, and a full baffle seeep isn't the cleanest of jobs. Utility at the very best imo. @NIreland what about buying an external oil boiler ( if we're assuming oil ) and leave it outside ready for relocation when you do have a garage. Then just use the digger for your founds to chop you a path for the pipework, and bingo. No noise, no smell, and can be serviced without entry to the property. 1
NIreland Posted September 19, 2017 Author Posted September 19, 2017 It's oil, have space in utility room , must check with plumber what type it is and see if anyone has any experiences with it
Nickfromwales Posted September 19, 2017 Posted September 19, 2017 Oh, sorry, are you saying you already have the boiler ?
