Struggling to get a gate we like at a sensible price. As suggested on a previous thread, I'm making my own.
Keeping it quite basic, 4m clear opening, each leaf 1.5m tall, metal frame, hardwood panel infill:
Some questions:
Metal frame: assuming 50x50x3mm SHS OK for the job? Planning on using L shaped angle to fix the wood panels to. I'm OK at welding...
Hinges: Any recommendations?
Latch / Lock. I'm getting an opening kit. What kind of latch/lock do I need (if any?)
Wood: Thinking 150x25mm hardwood planks for longevity. We'll be painting/staining. Do I need T&G panels, butt, biscuit join? Don't want cracking/splitting.
Anything else to consider?
Thanks
Can you get it galv at reasonable cost?  If they are hinged be aware that a strong wind will be an issue so timber infill is not ideal.   If they are automatic you obvs need power and cabling.  A friend does these and likes FAAC.  Videx for the intercom.  Be very aware of safety requirements so nobody can get crushed between or behind them.
Might want to put spaces between the boards - lets the wind through without making your gates two big sails.
I always liked vertical boards set edge on - gives the gate a bit more of a contemporary look.
