stevew85 Posted December 31, 2023 Posted December 31, 2023 hi everyone im looking for instructions on changing the old control panel to the newer part number- 497808 vent axia have sent me the newer version as the original is now obsolete, however there is no instructions in the box and they are closed for xmas holidays. has anyone had experience of changing these over. any info appreciated.
ProDave Posted December 31, 2023 Posted December 31, 2023 Post a picture of old and new and it might be obvious.
dpmiller Posted December 31, 2023 Posted December 31, 2023 if the original item is obsoleted for whatever reason (component shortage post-COVID is common...) I'd expect the replacement to be a direct swap and if not come with instructions.
stevew85 Posted December 31, 2023 Author Posted December 31, 2023 yeh its definitely not a straight swap as there is no power bus cable on it that goes to the other smaller pcb. yes i expected instructions as well as its mostly plug in connections
Andehh Posted December 31, 2023 Posted December 31, 2023 How old is your unit? Mine was a like for like swap, all pokey yoke... But then I replaced a board within 6 months of the original throwing a wobbly.
dpmiller Posted January 1, 2024 Posted January 1, 2024 plenty of colour-coded adapter cables then, the only query looks like the ribbon cable?
ProDave Posted January 1, 2024 Posted January 1, 2024 I say it needs instructions. Pester them for the instructions. While some of it might be obvious there are for instance 2 identical 3 pin connectors on the new board. It may or may not matter if they are connected the wrong way, but I would prefer to know rather than hope.
Alan Ambrose Posted January 1, 2024 Posted January 1, 2024 Yeah as an electronics guy … I suggest asking for the whole unit to be replaced. It’s not your fault that they have completely redesigned the pcb with no thought to upward compatibility. The fact they have an ‘upgrade kit’ with all the adapter cables suggests a major design fault and that lots of these units are failing in the field. Or ask for you money back and buy a different brand.
stevew85 Posted January 1, 2024 Author Posted January 1, 2024 15 hours ago, Andehh said: How old is your unit? Mine was a like for like swap, all pokey yoke... But then I replaced a board within 6 months of the original throwing a wobbly. my unit is 5 years old
Alan Ambrose Posted January 1, 2024 Posted January 1, 2024 (edited) OK in that case I would just 'follow my nose' matching up the connectors and yellow and green cable/pcb markings (see images below). 7 out of 8 seem pretty obvious - there's probably yellow and green marked on the other sockets on the unit too. The only one I can't figure is the power cable - that might be more obvious to you with them in your hands. Maybe photograph both ends (pcb & unit body connections) of the old set-up. And the new set-up before powering on and post here. Edited January 1, 2024 by Alan Ambrose
Jonro99 Posted April 8, 2024 Posted April 8, 2024 On 31/12/2023 at 10:53, stevew85 said: hi everyone im looking for instructions on changing the old control panel to the newer part number- 497808 vent axia have sent me the newer version as the original is now obsolete, however there is no instructions in the box and they are closed for xmas holidays. has anyone had experience of changing these over. any info appreciated. Hi, my Vent Axia has recently given up too. I need to replace the PCB and after speaking to the tech support guys I know I need the updated PCB and patch cables. The guys said that the new PCB replaces both of the current boards. I can see that the power from the house goes directly from the isolator box to the green block at the bottom of the new PCB, and the majority of the patch cables seem pretty straight forward. The only cable I am not sure about is the cable that @Alan Ambrosehasn't circled, where does this go? And how does the control panel get connected up? Do you have any instructions or photos of your installation? Any help here is appreciated.
David Hunter Posted March 16, 2025 Posted March 16, 2025 On 31/12/2023 at 10:53, stevew85 said: hi everyone im looking for instructions on changing the old control panel to the newer part number- 497808 vent axia have sent me the newer version as the original is now obsolete, however there is no instructions in the box and they are closed for xmas holidays. has anyone had experience of changing these over. any info appreciated. Hi Steve. Is the display screen attached to that PCB. I need to replace my inner PCB (439155) and the suppliers quoted the same part as you have above as the replacement. They said that it replaces the 2 piece PCB. So I don't know if they mean it replaces the inner PCB (439155) and the outer PCB (439150). Or if it replaces the 439150 and the display screen. They were very confused when I asked them
Jonro99 Posted March 16, 2025 Posted March 16, 2025 3 hours ago, David Hunter said: Hi Steve. Is the display screen attached to that PCB. I need to replace my inner PCB (439155) and the suppliers quoted the same part as you have above as the replacement. They said that it replaces the 2 piece PCB. So I don't know if they mean it replaces the inner PCB (439155) and the outer PCB (439150). Or if it replaces the 439150 and the display screen. They were very confused when I asked them No, the screen is not included/replaced. The old screen plugs into the new PCB.
David Hunter Posted March 19, 2025 Posted March 19, 2025 On 16/03/2025 at 15:42, Jonro99 said: No, the screen is not included/replaced. The old screen plugs into the new PCB. Thanks Jonro. My screen looks like it's soldered onto the old PCB though
Jonro99 Posted March 19, 2025 Posted March 19, 2025 27 minutes ago, David Hunter said: Thanks Jonro. My screen looks like it's soldered onto the old PCB though It's been a while since I did mine and I don't remember whether you connect the new PCB to the PCB with the screen on it. I have a remote screen downstairs and do all the changes there anyway. This is the only other information I have about the new PCB
David Hunter Posted June 18, 2025 Posted June 18, 2025 Have had to replace the summer bypass actuator as well, can anyone tell me which terminalnis the + poaitive and which is the - negative as i havnt a clue. Any help is great fully received and much appreciated
Nickfromwales Posted June 18, 2025 Posted June 18, 2025 2 hours ago, David Hunter said: Have had to replace the summer bypass actuator as well, can anyone tell me which terminalnis the + poaitive and which is the - negative as i havnt a clue. Any help is great fully received and much appreciated If A/C voltage goes to it there is no polarity. Polarity only features with D/C equipment. Hope that helps.
Christie Posted November 10, 2025 Posted November 10, 2025 On 19/03/2025 at 19:45, David Hunter said: Thanks Jonro. My screen looks like it's soldered onto the old PCB though Hi David, How did you get on with this? I am going to be replacing my PCB with the new one with patch cables that replaces the 2 I have currently. My screen is the same as yours, how did you get on with yours? Were you able to keep the screen? Thanks Fraser
Christie Posted November 18, 2025 Posted November 18, 2025 On 08/04/2024 at 17:48, Jonro99 said: Hi, my Vent Axia has recently given up too. I need to replace the PCB and after speaking to the tech support guys I know I need the updated PCB and patch cables. The guys said that the new PCB replaces both of the current boards. I can see that the power from the house goes directly from the isolator box to the green block at the bottom of the new PCB, and the majority of the patch cables seem pretty straight forward. The only cable I am not sure about is the cable that @Alan Ambrosehasn't circled, where does this go? And how does the control panel get connected up? Do you have any instructions or photos of your installation? Any help here is appreciated. Hello, I’m just about to replace my PCB and also wondering where this wire goes? Did you find out? thanks
