hi everyone im looking for instructions on changing the old control panel to the newer part number- 497808
vent axia have sent me the newer version as the original is now obsolete, however there is no instructions in the box and they are closed for xmas holidays. has anyone had experience of changing these over.  any info appreciated.
if the original item is obsoleted for whatever reason (component shortage post-COVID is common...) I'd expect the replacement to be a direct swap and if not come with instructions.
yeh its definitely not a straight swap as there is no power bus cable on it that goes to the other smaller pcb.
yes i expected instructions as well as its mostly plug in connections
How old is your unit? Mine was a like for like swap, all pokey yoke... But then I replaced a board within 6 months of the original throwing a wobbly.
I say it needs instructions.  Pester them for the instructions.  While some of it might be obvious there are for instance 2 identical 3 pin connectors on the new board.  It may or may not matter if they are connected the wrong way, but I would prefer to know rather than hope.
Yeah as an electronics guy … I suggest asking for the whole unit to be replaced. It’s not your fault that they have completely redesigned the pcb with no thought to upward compatibility. The fact they have an ‘upgrade kit’ with all the adapter cables suggests a major design fault and that lots of these units are failing in the field. Or ask for you money back and buy a different brand.
my unit is 5 years old
OK in that case I would just 'follow my nose' matching up the connectors and yellow and green cable/pcb markings (see images below). 7 out of 8 seem pretty obvious - there's probably yellow and green marked on the other sockets on the unit too.
The only one I can't figure is the power cable - that might be more obvious to you with them in your hands.
Maybe photograph both ends (pcb & unit body connections) of the old set-up. And the new set-up before powering on and post here.
Edited by Alan Ambrose
  • 3 months later...
Hi, my Vent Axia has recently given up too. I need to replace the PCB and after speaking to the tech support guys I know I need the updated PCB and patch cables. The guys said that the new PCB replaces both of the current boards.
I can see that the power from the house goes directly from the isolator box to the green block at the bottom of the new PCB, and the majority of the patch cables seem pretty straight forward. The only cable I am not sure about is the cable that @Alan Ambrosehasn't circled, where does this go? And how does the control panel get connected up?
Do you have any instructions or photos of your installation?
Any help here is appreciated.
  • 11 months later...
Hi Steve. Is the display screen attached to that PCB. I need to replace my inner PCB (439155) and the suppliers quoted the same part as you have above as the replacement. They said that it replaces the 2 piece PCB.
So I don't know if they mean it replaces the inner PCB (439155) and the outer PCB (439150).
Or if it replaces the 439150 and the display screen.
They were very confused when I asked them
No, the screen is not included/replaced. The old screen plugs into the new PCB.
Thanks Jonro.
My screen looks like it's soldered onto the old PCB though
27 minutes ago, David Hunter said:
Thanks Jonro.
It's been a while since I did mine and I don't remember whether you connect the new PCB to the PCB with the screen on it. I have a remote screen downstairs  and do all the changes there anyway.
This is the only other information I have about the new PCB
  • 2 months later...
Have had to replace the summer bypass actuator as well, can anyone tell me which terminalnis the + poaitive and which is the - negative as i havnt a clue. Any help is great fully received and much appreciated
If A/C voltage goes to it there is no polarity. Polarity only features with D/C equipment. Hope that helps.
  • 4 months later...
On 19/03/2025 at 19:45, David Hunter said:
Thanks Jonro.
Hi David,
How did you get on with this? I am going to be replacing my PCB with the new one with patch cables that replaces the 2 I have currently. My screen is the same as yours, how did you get on with yours? Were you able to keep the screen?
Thanks
Fraser
Hello,
I’m just about to replace my PCB and also wondering where this wire goes? Did you find out?
thanks
