MarkW1979 Posted December 30, 2023 Share Posted December 30, 2023 Hi all, and a happy to New Year when it comes. My plumber needs to know the sizes of radiators I am using and as usual I have left planning it to the last minute and thought interpreting the information I have from the heat pump installer would be straightforward (it may be that I am just overcomplicating things as usual!). The heat pump installer has provided the heat loss calcs for the rooms. I am only having rads in the bedrooms: 1,2 & 3. The radiators I am finding online seem to only need to be fairly small to match the wattage calcs as recorded below (at Delta 50) - I had expected them to be required to be much larger (i.e. oversized for a HP). Am I missing something? Should I be looking at achieving the stipulated wattages at Delta 30? Thanks in advance! Link to comment Share on other sites More sharing options...
JohnMo Posted December 30, 2023 Share Posted December 30, 2023 All the info you need https://www.heatgeek.com/do-i-need-to-upgrade-my-radiators-for-a-heat-pump/#google_vignette 1 Link to comment Share on other sites More sharing options...
Marvin Posted December 30, 2023 Share Posted December 30, 2023 Hi @MarkW1979 Delta 30. That's the difference between the room temperature and the water temperature entering the radiator (so 20C room 50C ASHP water) Link to comment Share on other sites More sharing options...
MarkW1979 Posted December 30, 2023 Author Share Posted December 30, 2023 Thanks guys, lightning fast response as usual! All the best Link to comment Share on other sites More sharing options...
SimonD Posted December 30, 2023 Share Posted December 30, 2023 On those bedroom losses, you'll be looking at T22 (double panel) at somewhere around 600mm high x 500mm wide mark Delta 30 so if you went 600 x 600 or even bigger, you could reduce your flow temps by a bit Link to comment Share on other sites More sharing options...
HughF Posted December 30, 2023 Share Posted December 30, 2023 Multiply the radiator output by 0.41 to go from delta-t 50 to delta-t 30 (70 degree flow, down to 50 degree flow). Link to comment Share on other sites More sharing options...
SteamyTea Posted December 30, 2023 Share Posted December 30, 2023 As a rule of thumb, if you halve the ∆T, then double the surface area, then round up to the next available size. 1 Link to comment Share on other sites More sharing options...
