I'm in the market for a pruning chainsaw - one of those which is 6", 8" or 10" long.
Circumstances:
1 - I have a set of remains of shrub to remove to ground level or just below to put a fence across the top. Needs doing PDQ and my handyman is not available to dig it all out by the roots.
2 - Having been ill quite long term I have a number of small-medium sized (4m->7m high ish) fruit trees which need some pruning, having got somewhat out of control.
3 - I use Makita, and have lots of batteries.
SO I think I am after 2 items:
1 - A Makita pruning chainsaw for longer term use. With versions of normal chainsaw features.
2 - Possibly a cheap as chips Makita battery compatible one that I can afford to risk breaking. There seem to be Chinese ones around for <£50, which have no chain lubrication system but I have an oil can.
Can anyone recommend models or sources?
As ever, all comments, and especially cautions, are welcome.
Thanks
Ferdinand
Would a reciprocating saw do the job? Easily handle 4" stems. I find them way more versatile and easier to use than a chainsaw. Unless you need something long reach?
  • Like 3
Chain saws blunt quickly if they are cutting soil. I think a reciprocating saw with more easily replacable blades is the way to go if cutting at ground level.
I bought an Oregon chainsaw (electric) good thing it has a self sharpening device, so 10 secs to sharpen the chain. Great for taking the odd branch off.
