JackofAll Posted November 14, 2023 Posted November 14, 2023 Has anyone insulated their service cavity, if so what did you use? Any concerns re cable in contact with insulation?
Crofter Posted November 15, 2023 Posted November 15, 2023 It's pretty straightforward to look up the effect of burying a cable in insulation. You may have go up a size to stay within safe limits. I chose not to insulate the service void. Mine was only 25mm deep so it would have had a negligible benefit, and would have completed any future wiring runs.
SteamyTea Posted November 15, 2023 Posted November 15, 2023 Rather than do two lots of calculations, insulated and uninsulated. Assume the cavity is insulated and size the cable to that.
Pocster Posted November 15, 2023 Posted November 15, 2023 Sorry - mis interpreted the title - thought it was a request .
SteamyTea Posted November 15, 2023 Posted November 15, 2023 23 minutes ago, Pocster said: Sorry - mis interpreted the title - thought it was a request . I did not know you had a Scotch name in the real world. Phil McCavity. How is your best friend, Ben Doon.
JohnMo Posted November 15, 2023 Posted November 15, 2023 When you look at the benefits of anmdding insulation compared to an unventilated cavity, found it wasn't worth the effort or expense. From build desk The calculation method can sometimes produce the same result for a range of airspace thicknesses. For example, the thermal resistance of air layers (i.e. undivided airspaces) with high-emissivity surfaces and a horizontal heat flow (the case for most unfilled cavities in external walls) is 0.18m2K/W for all thicknesses from 20mm to 300mm. A mineral wool would give a 4 to 5 time better performance, a 25mm cavity with 0.032 mineral wool would add (excluding thermal bridging of wooden battens), 0.78 to your R value The unvented cavity around 0.14. Assuming your R value was already 8 Insulated U value ends up 0.114 (plus some for battens thermal bridges) Empty U value ends up 0.123 (note the thermal resistance of wood and the air space is very similar, so little bridging to add. So impact on U value is circa 0.01 or less 1
Kelvin Posted November 15, 2023 Posted November 15, 2023 I looked at it too and as John says it wasn’t worth the effort and cost. Plus the way we did ours allows us to easily add more services in the future etc which we’d lose if we insulated it.
JackofAll Posted November 15, 2023 Author Posted November 15, 2023 Thanks guys, it's a 25mm cavity, thought insulating it would have made more of a difference. Alot of effort/expense as you put it John.
