Kimmiju Posted November 11, 2023 Posted November 11, 2023 Hi  I’m new here so apologies if this is in the wrong area. I took over a house a year or so back and there are a number of jobs that need doing so I expect I’ll be asking lots of questions here 😂 first… the windows at the front are badly fitted and look botched. Whoever fitted them just filled the inch or so gap at the top with silicone and it’s splitting. any advice on the correct/best way to fix this (without replacing the windows) would be greatly appreciated. initially I thought that expanding foam might work then silicone or some kind of cover strip. It’s obviously letting water in, some days when it rains hard water is running down the inside of the windows.  tia.Â
ToughButterCup Posted November 11, 2023 Posted November 11, 2023 A few photos would help us help you .... 2
gaz_moose Posted November 12, 2023 Posted November 12, 2023 foam it, then trim it, then silicone it. Â how are they actually fitted in? if you open the window sashes are there big screws going through the frames? Â Window Sill | Window Board | Eurocell 1
Kimmiju Posted November 13, 2023 Author Posted November 13, 2023 Sorry. Thought I’d added this photo @ToughButterCup  @gaz_moose looks like they’re fitted with screws as you say
Conor Posted November 13, 2023 Posted November 13, 2023 What's at the other end of the gap? A piece of plastic trim? Looks like window is way too small. You'll want to rake all that out and get a plasterer in and put a new bead and build render to meet the frame. 1
markc Posted November 13, 2023 Posted November 13, 2023 Can’t see anything drastically wrong with the window, the piece coming away looks like a lintel. What is is made of?
MAB Posted November 13, 2023 Posted November 13, 2023 (edited) First thing to do is cut out/remove all that silicone and filler 'bodge up' in the gap above the window frame......then see how deep it is or if it goes right through to the inside wall, then take some more photos inside and out and post the photos here for further help/comment on what to do to rectify the problem. Edited November 13, 2023 by MAB 1
joe90 Posted November 14, 2023 Posted November 14, 2023 8 hours ago, MAB said: First thing to do is cut out/remove all that silicone and filler 'bodge up' in the gap above the window frame......then see how deep it is or if it goes right through to the inside wall, then take some more photos inside and out and post the photos here for further help/comment on what to do to rectify the problem. +1, get all that sh1t removed and see what you have got (and post pics here). 1
ToughButterCup Posted November 14, 2023 Posted November 14, 2023 @joe90 forgot to say .... Get a pest Control guy to remove the mice, rats , bats and GCNs. When that's done replace the inevitably rotten(ing) wood , and when you've done that replace the lintel(s) and then the frame.  Or - keeping it brief - knock the house down and start again. 😑 1
