I’m thinking of adding two (or maybe four?) triple-glazed roof lights to my small building refurbishment. Nothing fancy or large, maybe 600mm x 900mm in size. It’s a small space (32msq) in the Outer Hebrides, so solar gain would probably be a benefit 🤣
I want them to finish flush to the pitched roof (not stand proud or be protruding) to avoid wind noise. They don’t need to be opening, as it's a single-volume space with lower windows.
I know Velux have a widely recognisable brand name, but are they the best company/windows to use, or are there other companies I should also be considering?
Velux are the popular choice for a reason. They’re simple to fit and do the job! Just like Eclisse with pocket doors. Personally I wouldn’t use any other
but I’m no expert and haven’t even finished my build yet. 😂
Velux here. My understanding is they can’t fit flush and need a minimum upstand. If they were flush wouldn’t rain run down the roof and across the window?
Ours  are opening and fiited on a standing seam roof so it might be different for fixed rooflights on a different roof. Ours are fitted direct to the roof deck and the frame provides the upstand which is 90mm. There’s a flashing around it and another over this so the rain runs down and around the window.
4 minutes ago, Chris HB said:
I thought they were doing a flush or at least a low profile window?
Dunno. Call them and ask.
This is ours.
dji_fly_20231017_144604_187_1697550377347_photo.thumb.jpeg.5f62555c35bcd4fdf324798eead826b0.jpegIMG_9716.thumb.jpeg.8aabb31d1cac4f1739936ceecc6880f9.jpeg
The Velux ones can be fitted at 2 levels of upstand so you can make them more flush but you need to get the flashing kit to suit.
We used a Fakro triple glazed roof window. Easy to fit, no trickle vents, no problems. Velux at that time only came with trickle vents.
