Chris HB Posted October 23, 2023 Posted October 23, 2023 I’m thinking of adding two (or maybe four?) triple-glazed roof lights to my small building refurbishment. Nothing fancy or large, maybe 600mm x 900mm in size. It’s a small space (32msq) in the Outer Hebrides, so solar gain would probably be a benefit 🤣 I want them to finish flush to the pitched roof (not stand proud or be protruding) to avoid wind noise. They don’t need to be opening, as it's a single-volume space with lower windows. I know Velux have a widely recognisable brand name, but are they the best company/windows to use, or are there other companies I should also be considering?
Thorfun Posted October 23, 2023 Posted October 23, 2023 Velux are the popular choice for a reason. They’re simple to fit and do the job! Just like Eclisse with pocket doors. Personally I wouldn’t use any other but I’m no expert and haven’t even finished my build yet. 😂 1
Kelvin Posted October 23, 2023 Posted October 23, 2023 Velux here. My understanding is they can’t fit flush and need a minimum upstand. If they were flush wouldn’t rain run down the roof and across the window? Ours are opening and fiited on a standing seam roof so it might be different for fixed rooflights on a different roof. Ours are fitted direct to the roof deck and the frame provides the upstand which is 90mm. There’s a flashing around it and another over this so the rain runs down and around the window. 1
Chris HB Posted October 23, 2023 Author Posted October 23, 2023 I thought they were doing a flush or at least a low profile window?
Kelvin Posted October 23, 2023 Posted October 23, 2023 4 minutes ago, Chris HB said: I thought they were doing a flush or at least a low profile window? Dunno. Call them and ask. This is ours. 1
Chanmenie Posted October 23, 2023 Posted October 23, 2023 Also have a look at Keylite windows, easy to fit, have a built in expanding thermal collar, the quality looks on par with Velux 2
Thorfun Posted October 24, 2023 Posted October 24, 2023 The Velux ones can be fitted at 2 levels of upstand so you can make them more flush but you need to get the flashing kit to suit. 1
Gone West Posted October 24, 2023 Posted October 24, 2023 16 hours ago, Chris HB said: are there other companies I should also be considering We used a Fakro triple glazed roof window. Easy to fit, no trickle vents, no problems. Velux at that time only came with trickle vents. 1
