Shower Valve Handle
Onoff
25 minutes ago, ProDave said:
You need a screw extractor set, something like this https://www.machinemart.co.uk/p/6-piece-screw-extraction-set-3---25mm/
You drill a pilot hole into the broken off stuck but then the screw extractor will bit into that pilot hole and unscrew it.
Thanks, I have one. Sods Law it'll be dissimilar metals and corroded tight!
