Barney12 Posted August 31, 2017 Posted August 31, 2017 Hi All Can anyone recommend a floor levelling screed that is suitable for a 22mm caberdeck chipboard floor. Its going to need to go from 20mm to 0mm. The floor is capable of taking a 50mm screed so no issues with structural integrity but I'm concerned about flexibility. The eventual floor finish is still in debate but most likely engineered oak but possibly carpet if someone gets her way. TA!
Nickfromwales Posted August 31, 2017 Posted August 31, 2017 Mapei Is it undulating 0-20mm or can you bulk areas out first with 6 / 9 / 12 / 15mm plywood first ? A lot quicker to bulk out first, and saves a lot of leveller.
Barney12 Posted August 31, 2017 Author Posted August 31, 2017 Just now, Nickfromwales said: Mapei Is it undulating 0-20mm or can you bulk areas out first with 6 / 9 / 12 / 15mm plywood first ? A lot quicker to bulk out first, and saves a lot of leveller. Ta. No, its sloping right to left in a uniform manner. Installed wonky!
Nickfromwales Posted August 31, 2017 Posted August 31, 2017 Get some ply down in the worst part then, glued and screwed, and then level the difference. What's the floor covering going to be ?
Barney12 Posted August 31, 2017 Author Posted August 31, 2017 3 minutes ago, Nickfromwales said: Get some ply down in the worst part then, glued and screwed, and then level the difference. What's the floor covering going to be ? 3rd line of OP. Try and keep up
Nickfromwales Posted August 31, 2017 Posted August 31, 2017 Just now, Barney12 said: 3rd line of OP. Try and keep up Haven't had my second coffee yet, plus ordering parts for my current job, plus charging my chuffing van as the back door wasn't shut properly last night so the battery went flat. "Finger of fudge". ?
Barney12 Posted August 31, 2017 Author Posted August 31, 2017 Just now, Nickfromwales said: Haven't had my second coffee yet, plus ordering parts for my current job, plus charging my chuffing van as the back door wasn't shut properly last night so the battery went flat. "Finger of fudge". ? Oooh go on then. But I'd prefer a Curly Wurly.
Barney12 Posted August 31, 2017 Author Posted August 31, 2017 2 minutes ago, Nickfromwales said: Haven't had my second coffee yet, plus ordering parts for my current job, plus charging my chuffing van as the back door wasn't shut properly last night so the battery went flat. "Finger of fudge". ? P.S. Get one of these. I keep mine charged up and its got me out of jail a couple of times: http://www.ebay.co.uk/itm/12V-PORTABLE-CAR-JUMP-STARTER-AIR-COMPRESSOR-BATTERY-START-BOOSTER-CHARGER-LEADS/182461430331?_trkparms=aid%3D555014%26algo%3DPL.DEFAULT%26ao%3D1%26asc%3D20160706105120%26meid%3Dd1804f2446d44b838ba3f4d7137e7bee%26pid%3D100508%26rk%3D1%26rkt%3D1%26&_trksid=p2045573.c100508.m3226
dpmiller Posted August 31, 2017 Posted August 31, 2017 so it's not just fridge doors that need an alarm then? 1
Pete Posted August 31, 2017 Posted August 31, 2017 28 minutes ago, Nickfromwales said: Haven't had my second coffee yet, plus ordering parts for my current job, plus charging my chuffing van as the back door wasn't shut properly last night so the battery went flat. "Finger of fudge". ? You can see where the kids get leaving the freezer door open from!!
