saveasteading Posted September 5, 2023 Posted September 5, 2023 3 minutes ago, Big Jimbo said: make sure I was onsite for an air test. Me too. When I was there the results were better. I don't know if "what number are you looking for" is an honest attempt at helping, but at least he knew a target and could report on the spot and look for an issue.
Iceverge Posted September 5, 2023 Posted September 5, 2023 @Newlands Ian Well done on getting it through the check. I would be inclined to side with @JohnMo on this one and chuck in a dMEV or two anyway. I wouldn't bother with the undercuts for now. At the very least spend £5 on a cheap humidistat to keep an eye on the humidity. Its you who will benefit from the better indoor air quality and lack of noise anyway. 1
Newlands Ian Posted September 6, 2023 Author Posted September 6, 2023 16 hours ago, Iceverge said: @Newlands Ian Well done on getting it through the check. I would be inclined to side with @JohnMo on this one and chuck in a dMEV or two anyway. I wouldn't bother with the undercuts for now. At the very least spend £5 on a cheap humidistat to keep an eye on the humidity. Its you who will benefit from the better indoor air quality and lack of noise anyway. As luck would have it, there is a humidity sensor on each of my thermostat/heating controllers so I can monitor it that way. Is there a dangerous level of humidity that it's advisable to stay below?
JohnMo Posted September 6, 2023 Posted September 6, 2023 Here is write up https://www.pettyson.co.uk/about-us/our-blog/792-what-should-humidity-be-in-a-house#:~:text=Both winter and summer levels,humidity levels%3A 30-50%
MikeSharp01 Posted September 6, 2023 Posted September 6, 2023 Just as an aside it is interesting how many posts we have seen on this topic, it must have hit the zeitgeist right on the head! 1
SteamyTea Posted September 6, 2023 Posted September 6, 2023 5 hours ago, Newlands Ian said: dangerous level of humidity that it's advisable to stay below The dew point is one. Td = T - ((100 - RH)/5) Where T is ⁰C, RH in % and above 50. For a longer explanation: https://en.m.wikipedia.org/wiki/Dew_point
