Hi all, looking at buying the membrane to cover our nudura walls. These walls will be battened, then the membrane put on, then batten over the top, so there will be an air space behind the membrane. I've been looking at the Tyvek Housewrap but this says it "Should be surface applied, fixed directly to sheathing ply /OSB, insulation or blockwork". Is it OK to use stapled to battens, or should I be looking for something else?
Thanks all
It's what the I was advised to do by my local Nudura distributor
I have to do this, then put a metal mesh, then a scratch coat before I can fit stone slips (think big tiles).
I need to think about this too. Might ask the stone slip Co.
On nudura or a different ICF?
Labc and nhbc have thrown some interesting curveballs for non-nudura installs.
