cables to kitchen island
I used 25mm PVC conduit with swept bends. The ends are accessible under the island and under the consumer unit.
I installed 10mm twin and earth.  Way over kill for a couple of sockets but it can be used in future should we decide to change for an induction hob.
If I really needed to I could pull something else through thanks to the swept bends.
We use a 63mm duct cut into EPS below the concrete, then coming up under the island and under the consumer unit.  Has a large supply for the induction hob, another supply for sockets and additional room for a lighting run etc if needed.
