JohnMo Posted November 8, 2023 Author Posted November 8, 2023 12 minutes ago, Iceverge said: Have you any evacuated tubes to tie onto it for the lower winter temps No, but I do have space on the frame for another panel or tubes. Sun's out this afternoon, so will have a look later to check how many kWh I produced today. By way of compensation my 22 PV panels are doing 2.5 to 3kW. So for the size ST is quite effective. 1
JohnMo Posted November 8, 2023 Author Posted November 8, 2023 4 hours ago, JohnMo said: Sun's out this afternoon, so will have a look later to check how many kWh I produced today Basically produced a whole 2kWh. But was enough for the heat pump stayed off for 4 hours from midday until around 4pm. Currently set to run 24/7 on WC.
JohnMo Posted April 6, 2024 Author Posted April 6, 2024 Just to finish the thread off Over the winter the solar thermal didn't really earn it's space, it did generate some energy when the sun was out, in short bursts , but not enough. So the panel was removed yesterday. May find a summer use for it, but not really why I got it.
Andeh Posted April 7, 2024 Posted April 7, 2024 Hot water for washing the car, or a paddling pool etc etc!
JohnMo Posted April 7, 2024 Author Posted April 7, 2024 4 hours ago, Andehh said: Hot water for washing the car, or a paddling pool etc etc! I was thinking something similar - have a detached garage some way from the house. It has water, I have a no longer used thermal store, roof does have some shading, but may be workable.
