AliG Posted September 28, 2017 Share Posted September 28, 2017 Hard to say about dormers without knowing the roof pitch. The lower the pitch, the less the roof will intrude. Bedroom 2 and 3 are large enough that they can probably take a lower height area, in bedroom 1 it looked like it would really intrude. Not sure from a design perspective it would look great to have lots of dormers. Link to comment Share on other sites More sharing options...
mikalscad Posted November 12, 2017 Share Posted November 12, 2017 this is a project i did recently using off the shelf building materials and the full potential of building regulations you might find them useful project schedule for 4bed detached house.pdf 4 bedroom detached house.pdf Link to comment Share on other sites More sharing options...
Ed_MK Posted January 2, 2018 Share Posted January 2, 2018 Very useful Mikal especially to remind first timers what comes where ...although ours is Potton/Timberframe ..a lot still applies ! Fro me now I am faced with filling out the dreaded Building Regulations Document ...its so confusing ...They refer to Building Reg and building control and Some other "faster" document Also from what i can see ...you don't HAVE to wait for the Building regulations to be "approved" ..I mean are they approved? As from what i can read as soon as you send them in you seem to be able to start ..that cant be right can it ? I have a lot of the documents that SEEM to be required from the ones i put in for Planning Permission (which was granted) And I am waiting for Potton to finish their BIT OF IT ...6 weeks after you pay deposit. I am presuming the Groundworks company have to submit something as well? As I am technically (due to finances) the project manager ...I guess I will be doing the services diagram and sending them in samples of outside and border materials I take it it is only THEN (once i have collated all the above) I actually fill in (and pay the £800!) for the Building Regs and then .... Link to comment Share on other sites More sharing options...
Ferdinand Posted January 2, 2018 Share Posted January 2, 2018 On 12/11/2017 at 11:59, mikalscad said: this is a project i did recently using off the shelf building materials and the full potential of building regulations you might find them useful project schedule for 4bed detached house.pdf 4 bedroom detached house.pdf THat is interesting. TRying to understand, can you confirm where eg the labour for fitting the windows is identified? Cheers F Link to comment Share on other sites More sharing options...
Mr Punter Posted January 2, 2018 Share Posted January 2, 2018 3 hours ago, Ed_MK said: Also from what i can see ...you don't HAVE to wait for the Building regulations to be "approved" ..I mean are they approved? As from what i can read as soon as you send them in you seem to be able to start ..that cant be right can it ? If you are doing a new build, get your architect / technician to do a "Full Plans" building regs submission. This should specify how each of the regs (structure, fire, conservation of fuel etc) will be met. It may be that the submission gets full approval, so you can just go ahead, conditional approval, saying that some further information will be needed down the line, or refused, which means you would need to reapply. It is possible to go ahead just by applying for a "Building Notice" but this is really only suited to minor works as you run the serious risk that at any stage the building inspector can ask you to re-do what you have done. The benefit of having full plans drawn up, with a specification, is that any supplier or contractor can see clearly what they are intended to do and as long as you build according to the approved plans the building inspector should be (fairly) happy. Link to comment Share on other sites More sharing options...
