Roger440 Posted February 26, 2024 Posted February 26, 2024 Me? Because connecting to the grid adds cost and complexity. I can consume everything i could generate in winter for heating, reducing the use of oil. Keeping this part off grid means i can do what i like, and myself. If only i understood it.
Roger440 Posted February 26, 2024 Posted February 26, 2024 3 hours ago, SteamyTea said: Had a quick look, most of it is generic stuff like cables, switches and connectors. There are the modules and batteries, then the charge controller/inverter, the MPPT and the communication device (which is probably not needed, but is used to set up the system, so will be needed, think of it as a specialised spanner). As it is all Victron kits, I suspect it is well sized for the system and won't be unreliable, why you pay a lot extra for it, they have done the leg work. I am sure of you ask Bimble, they will have an installation guide. If you say its good gear, im sure it is. Its somewhat acedemic, however, as there absolutely no chance of me spending that kind of money. It would be irrational. If what i do isnt at least close to making financial sense, im not doing it.
Dillsue Posted February 26, 2024 Posted February 26, 2024 1 hour ago, Roger440 said: Because connecting to the grid adds cost and complexity. I can consume everything i could generate in winter for heating, reducing the use of oil. Keeping this part off grid means i can do what i like, and myself. If only i understood it. Unless you've got a massive array its almost certain you'll use everything you generate in the winter and a fair chance you'll need more on occasion. The 4.5 kw you've got on a pallet will just scratch the surface in the winter. Even with a big array how are you going to power things if you have a run of bad weather. What if you have a breakdown without the back up of a grid connected system? Assuming your house already has a mains supply, connecting up PV costs can be minimal. Export less than 3.68kw and DNO costs are £0. Getting a spark to make the final connection to your consumer unit can be a couple of hundred £, less if youre well acquainted. The rest you can do yourself with research.
Roger440 Posted February 26, 2024 Posted February 26, 2024 (edited) 40 minutes ago, Dillsue said: Unless you've got a massive array its almost certain you'll use everything you generate in the winter and a fair chance you'll need more on occasion. The 4.5 kw you've got on a pallet will just scratch the surface in the winter. Even with a big array how are you going to power things if you have a run of bad weather. What if you have a breakdown without the back up of a grid connected system? Assuming your house already has a mains supply, connecting up PV costs can be minimal. Export less than 3.68kw and DNO costs are £0. Getting a spark to make the final connection to your consumer unit can be a couple of hundred £, less if youre well acquainted. The rest you can do yourself with research. Its up there somewhere ^^^. Im connected to the grid. Heating is oil, and thats going nowhere. This would supplement it. Ideally to drive an ASHP to heat water in a massive tank. Ie, storing the energy as hot water instead of batteries. The principle being simple enough. Whilst the current array is 4.5kw, the panels are circa £100 each off ebay and i have unlimited space so would be able to expand. JohnMo seems to be getting some worthwhile output from his vertical panels, circa 17Kwh per day out of a sub 8kw array. If we assume a COP of 3, thats becomes a worthwhile contribution to the daily heating requirements. But at the risk of repeating myself and boring everyone to death, this doesnt fly if i start paying people thousands to do work. No doubt ill have to have a smart meter to export, which wont work as there is zero signal. Really, just not interested in export. Or the hassle of buggering about fretting about tarrifs i dont understand, getting my export rate reduced arbitairly etc etc. I just want simple. If i cant install it and maintain it myself, then its not happening. I cannot be beholden to other people in the event of issues. Its borderline impossible get anyone to do anything out here. Sadly, i dont think i have enough understanding to design what i need. As per the previous few posts, what im trying to do seems simple in principle, but not so easy in practice. My initial enthusiasm is waning fast as reality strikes! Theres a whole bunch of cost to deal with to do this aside from the solar side. I need to build a shed to put said water tank in, which would house the boiler, ASHP, stanby genny, as well, relocation of plumbing, power supply etc etc etc.. I can do all that myself, but its still not free. As i also said earlier, this has to make economic sense. I appreciate many on here have applied "man maths" to there own justification or other reasons, or super long payback periods, but im not doing that. It has to make sense. The context is 2000 litres of oil a year. So £2k a year. With no capital investment required. Its all there, working and relatively new. So you see, it needs be pretty cheap to make it fly. I thought having a "free" array would tip things the right way. Edited February 26, 2024 by Roger440
joe90 Posted February 26, 2024 Posted February 26, 2024 22 minutes ago, Roger440 said: But at the risk of repeating myself and boring everyone to death, this doesnt fly if i start paying people thousands to do work. No doubt ill have to have a smart meter to export, which wont work as there is zero signal. Really, just not interested in export. Or the hassle of buggering about fretting about tarrifs i dont understand, getting my export rate reduced arbitairly etc etc. I just want simple. If i cant install it and maintain it myself, then its not happening. I cannot be beholden to other people in the event of issues. Its borderline impossible get anyone to do anything out here. Sadly, i dont think i have enough understanding to design what i need. As per the previous few posts, what im trying to do seems simple in principle, but not so easy in practice. My initial enthusiasm is waning fast as reality strikes! I get that completely so i guess it’s all down to payback timing, how much you want to invest and the time it will take to pay it off which will be linked to your consumption. I am sure there are people here that will help you design it.
JohnMo Posted February 26, 2024 Author Posted February 26, 2024 1 hour ago, Roger440 said: Its up there somewhere ^^^. Im connected to the grid. Heating is oil, and thats going nowhere. This would supplement it. Ideally to drive an ASHP to heat water in a massive tank. Ie, storing the energy as hot water instead of batteries. The principle being simple enough. Whilst the current array is 4.5kw, the panels are circa £100 each off ebay and i have unlimited space so would be able to expand. JohnMo seems to be getting some worthwhile output from his vertical panels, circa 17Kwh per day out of a sub 8kw array. If we assume a COP of 3, thats becomes a worthwhile contribution to the daily heating requirements. But at the risk of repeating myself and boring everyone to death, this doesnt fly if i start paying people thousands to do work. No doubt ill have to have a smart meter to export, which wont work as there is zero signal. Really, just not interested in export. Or the hassle of buggering about fretting about tarrifs i dont understand, getting my export rate reduced arbitairly etc etc. I just want simple. If i cant install it and maintain it myself, then its not happening. I cannot be beholden to other people in the event of issues. Its borderline impossible get anyone to do anything out here. Sadly, i dont think i have enough understanding to design what i need. As per the previous few posts, what im trying to do seems simple in principle, but not so easy in practice. My initial enthusiasm is waning fast as reality strikes! Theres a whole bunch of cost to deal with to do this aside from the solar side. I need to build a shed to put said water tank in, which would house the boiler, ASHP, stanby genny, as well, relocation of plumbing, power supply etc etc etc.. I can do all that myself, but its still not free. As i also said earlier, this has to make economic sense. I appreciate many on here have applied "man maths" to there own justification or other reasons, or super long payback periods, but im not doing that. It has to make sense. The context is 2000 litres of oil a year. So £2k a year. With no capital investment required. Its all there, working and relatively new. So you see, it needs be pretty cheap to make it fly. I thought having a "free" array would tip things the right way. There are two ways to heat water with electricity, heat pump or direct to immersion. Neither are as straightforward forward as they first seem. But breaking down practicality Heat pumps when you need them most they have the biggest power need (lowest CoP) and you are likely to have least PV available. So likely no heat pump running most of Dec-Jan. Looking at my PV today, which was quite overcast I did 17kWh, but the useful window for driving a heat pump off-grid was about 3 to 4 hrs. The other alternative would be direct DC to immersion heaters. You need to match the output of the panels very closely to the the power rating of the immersion to get them to perform as they should. You get a CoP of one, but you get useful energy whenever the sun's out. Panels from city plumbing are cheaper than ebay. Watch this and the spreadsheet mentioned is attached https://www.google.co.uk/url?sa=t&source=web&rct=j&opi=89978449&url=https://m.youtube.com/watch%3Fv%3DkVaxAfXQPDU&ved=2ahUKEwjZ2vnXhcqEAxXkZEEAHfX8DHkQo7QBegQIDhAG&usg=AOvVaw2ys-gKyKBdBX1Ku7fZDZ-M Solar PV Calculator.xlsx
Hastings Posted February 26, 2024 Posted February 26, 2024 7 hours ago, SteamyTea said: As it is all Victron kits, I suspect it is well sized for the system and won't be unreliable, why you pay a lot extra for it, they have done the leg work. Be aware there is no real tech support with Victron stuff. You post your problem on a forum and wait/hope for a response from the community.
Roger440 Posted February 27, 2024 Posted February 27, 2024 18 hours ago, JohnMo said: There are two ways to heat water with electricity, heat pump or direct to immersion. Neither are as straightforward forward as they first seem. But breaking down practicality Heat pumps when you need them most they have the biggest power need (lowest CoP) and you are likely to have least PV available. So likely no heat pump running most of Dec-Jan. Looking at my PV today, which was quite overcast I did 17kWh, but the useful window for driving a heat pump off-grid was about 3 to 4 hrs. The other alternative would be direct DC to immersion heaters. You need to match the output of the panels very closely to the the power rating of the immersion to get them to perform as they should. You get a CoP of one, but you get useful energy whenever the sun's out. Panels from city plumbing are cheaper than ebay. Watch this and the spreadsheet mentioned is attached https://www.google.co.uk/url?sa=t&source=web&rct=j&opi=89978449&url=https://m.youtube.com/watch%3Fv%3DkVaxAfXQPDU&ved=2ahUKEwjZ2vnXhcqEAxXkZEEAHfX8DHkQo7QBegQIDhAG&usg=AOvVaw2ys-gKyKBdBX1Ku7fZDZ-M Solar PV Calculator.xlsx 14.01 kB · 5 downloads Thanks for that. Hmmm, essentially you have pointed out my idea wont work, ie, use an ASHP. Essentially because, despite the overall collection, there will only be enough to run it for a short amount of time. Which, as you say, leaves the only option as direct immersion units. Clearly, it has simplicity on its side, as looking at that video there are no additional things other than panels and heating elements. (though with that level of simplicity how do you prevent overheating?) I need to do some more accurate calculations, but im not sure i see this making good financial sense. If i could just put the immersion into an exsisting tank, it might be OK, but given all the extra work to get to that point im not so sure. One thing i didnt understand in that video, is he showed how having them in series didnt work. But at the end on his calculator, he turned the sewries/parrall numbers round and still had the same output. Which directly contradicted himself. Dont understand that bit?
JohnMo Posted February 27, 2024 Author Posted February 27, 2024 1 hour ago, Roger440 said: how do you prevent overheating Immersion thermostat. 1 hour ago, Roger440 said: Dont understand that bit? I found I had to lots of different configurations on the spreadsheet to get anything usable. 1
JohnMo Posted 8 hours ago Author Posted 8 hours ago On 07/07/2023 at 08:45, JohnMo said: Full details of costs, all labour by myself, so not costed Panels 12x 285W, used £700 £40 fuel to collect panels Inverter £150 Posts and postcrete. £400 Unistrut, £300. 4 core cable and three core cable £300 Isolators AC and DC, generation meter, stickers and MC4 connectors, £99 M20 glands £2.50 M25 glands £30 Coach screws £9 M4 bolts and nuts £9 Square plate washer £13 M8 Allen bolt £18 Panel mounts £32 DC cable £70 MC4 connectors £7 So cost all in £2210, for a fully installed ground mount 3.4kW PV system. Array mounted 52m from inverter. Just been revising this thread and looking at pay back, we are now at about 2/3 point of payback at just over 2 years, so will be cost neutral in year 3. Looking at the costs PV panels have dropped in price quite a bit. These panels (second hand) including the fuel costs to collect, came in at £740. Same size array in bifacial 500W panels £525. So the whole system would have cost almost exactly £2000.
TedM Posted 6 hours ago Posted 6 hours ago 1 hour ago, JohnMo said: Just been revising this thread and looking at pay back, we are now at about 2/3 point of payback at just over 2 years, so will be cost neutral in year 3. Looking at the costs PV panels have dropped in price quite a bit. These panels (second hand) including the fuel costs to collect, came in at £740. Same size array in bifacial 500W panels £525. So the whole system would have cost almost exactly £2000. It's an interesting read 👍 My 4kWp E/W array [dating back 13 years I guess] is a bit rubbish in the winter... especially as a tree has grown over the years and now shades part of the W facing array during the winter months 🤦♂️ So I'm planning on adding another 2kWp which will face due South. It will be ground mounted and I'm planning on making a frame using scaffolding tube as a mate has a big scaffolding firm and will just drop round what I need! The frame will be mounted onto a concrete area that we have using key clamps bolted to the concrete and there will be 5 new panels angled fairly steeply initially. I'm going to use a new/old stock inverter off eBay to keep this array completely separate from the existing array so as not to risk the FIT payments. I've not got any batteries but do use an eddi diverter for hot water plus a bunch of Shelly power monitors and wireless relays that switch various heaters, etc on when the generation level is suitable. The only PITA is running the cabling from the panels to the inverter which will be in a stable about 30m away - I'm going to have to cut a channel into the concrete to bury it 😫 (the alternative is to mount the array about 150m away on the boundary of a paddock we have - then i could hire a trencher to help bury the cabling. There would also be room for a huge amount of panels there if I had the money/permission/desire)
Nestor Posted 6 hours ago Posted 6 hours ago 1 hour ago, JohnMo said: Just been revising this thread and looking at pay back, we are now at about 2/3 point of payback at just over 2 years, so will be cost neutral in year 3. Looking at the costs PV panels have dropped in price quite a bit. These panels (second hand) including the fuel costs to collect, came in at £740. Same size array in bifacial 500W panels £525. So the whole system would have cost almost exactly £2000. Thanks for the update. Would you have a figure for your annual generation you could share?
Roger440 Posted 4 hours ago Posted 4 hours ago This useful thread is a handy reminder of how little ive achieved on this front. (lots achieved elsewhere) The panels are still on a pallet. And i still dont understand enough to design something simple.
Dillsue Posted 3 hours ago Posted 3 hours ago 2 hours ago, TedM said: My 4kWp E/W array I'm going to use a new/old stock inverter off eBay to keep this array completely separate from the existing array so as not to risk the FIT payments. Don't forget you need DNO consent if total potential export is over 3.68kw. You can add generation to your FIT system as the rules changed a few years back. If your current system is under performing its likely beneficial to add to the FIT system rather than add a second separate system
Dillsue Posted 3 hours ago Posted 3 hours ago 1 hour ago, Roger440 said: And i still dont understand enough to design something simple. Fix panels so they face the sun at some point mid morning to mid afternoon. Plug panels together. Plug the 2 unconnected leads into an inverter using MC4 extension leads if needed. Connect inverter to nearest fuse board through an MCB specified by the inverter manufacturer. Switch the inverter on. Sit back smugly and thank the part P electrician who connected it up for you 1
Roger440 Posted 3 hours ago Posted 3 hours ago 6 minutes ago, Dillsue said: Fix panels so they face the sun at some point mid morning to mid afternoon. Plug panels together. Plug the 2 unconnected leads into an inverter using MC4 extension leads if needed. Connect inverter to nearest fuse board through an MCB specified by the inverter manufacturer. Switch the inverter on. Sit back smugly and thank the part P electrician who connected it up for you If you go back couple of pages you will see thats its not nearly so simple. If it was, id have done it by now.
Dillsue Posted 3 hours ago Posted 3 hours ago 11 minutes ago, Roger440 said: If you go back couple of pages you will see thats its not nearly so simple. If it was, id have done it by now. Forget trackers, forget batteries, forget diverters as none of those are needed to get your 4.5kw of panels up and running. You've said the mechanics of mounting them are fine and that's the tricky bit. You can plug and unplug the connectors on a car loom? MC4 connectors are no harder. Fix a 3.68kw inverter to the wall? Get a spark to connect up the mains if you don't want to do that. Fill in your name and address on a G98 and post it to your DNO. What else is stopping you??
Roger440 Posted 2 hours ago Posted 2 hours ago 4 minutes ago, Dillsue said: Forget trackers, forget batteries, forget diverters as none of those are needed to get your 4.5kw of panels up and running. You've said the mechanics of mounting them are fine and that's the tricky bit. You can plug and unplug the connectors on a car loom? MC4 connectors are no harder. Fix a 3.68kw inverter to the wall? Get a spark to connect up the mains if you don't want to do that. Fill in your name and address on a G98 and post it to your DNO. What else is stopping you?? It doesnt reduce my heating costs. Just gives me lots of electricity. That i cant really use. At least not when its generated Unless i do more stuff. Which costs more money. You dont just fill in your name and address on the G98 form. It asks for lots of other stuff, like who did it, their qualifications etc. If i do it myself, theres going to be a problem, surely? Happy to connect it up. I qualified way back under 16th edition. So i know enough to do that without killing myself. I like the system that Johnmo linked to, ie panels straight to immersion. No controllers, no electronics, no connection to the grid, no DNO bs, no trying to find an electrician, no complicated opaque tarriffs. Thats simple. Everything else just isnt. Accepting that what you say is simplish, but doesnt get me heat.
Crofter Posted 2 hours ago Posted 2 hours ago 3 minutes ago, Roger440 said: It doesnt reduce my heating costs. Just gives me lots of electricity. That i cant really use. At least not when its generated Unless i do more stuff. Which costs more money. You could load shift to when the sun is shining. Better than leaving those panels sat on a pallet. 3 minutes ago, Roger440 said: I like the system that Johnmo linked to, ie panels straight to immersion. No controllers, no electronics, no connection to the grid, no DNO bs, no trying to find an electrician, no complicated opaque tarriffs. Thats simple. Everything else just isnt. Accepting that what you say is simplish, but doesnt get me heat. Link?
Roger440 Posted 2 hours ago Posted 2 hours ago 2 minutes ago, Crofter said: You could load shift to when the sun is shining. Better than leaving those panels sat on a pallet. Link? How? That needs batteries, or a big water tank. Water tank was my original idea. Batteries are a non starter based on capital cost and payback. This was the video Johnmo posted up there^^^ https://www.google.co.uk/url?sa=t&source=web&rct=j&opi=89978449&url=https://m.youtube.com/watch%3Fv%3DkVaxAfXQPDU&ved=2ahUKEwjZ2vnXhcqEAxXkZEEAHfX8DHkQo7QBegQIDhAG&usg=AOvVaw2ys-gKyKBdBX1Ku7fZDZ-M The basic premise was to supplement the oil based heating with the "free" energy from solar. Using stuff i already have. Theres no economic case to move away from oil to electric as i cant, obviously, generate that much power.
Dillsue Posted 2 hours ago Posted 2 hours ago If you want batteries/diverter/heating you need the panels in place and connected, so get that first step done. Everything else is secondary and can be added if and when you get round to it. 4.5kw of panels will give a useful contribution to house running costs spring/summer and a bit of autumn. It's never going to heat your house or hot water in the winter. You can load shift anytime you want by scheduling washing machine, tumble drier, slow cooker etc etc to be on during the day when its bright. Do one after the other to minimise grid draw and max your self use...........but you know all this already so no one really needs to be repeating it??? Just put self installed on the G98, that's all my son in law did and all I did on our G99. Rest of the stuff is inverter details and if you've done electrical work you'll understand all that. Apparently the ENA estimates that less than 50% of PV install has been notified to DNOs so they'll probably be quite greatful of your notification
Roger440 Posted 1 hour ago Posted 1 hour ago 31 minutes ago, Dillsue said: If you want batteries/diverter/heating you need the panels in place and connected, so get that first step done. Everything else is secondary and can be added if and when you get round to it. 4.5kw of panels will give a useful contribution to house running costs spring/summer and a bit of autumn. It's never going to heat your house or hot water in the winter. You can load shift anytime you want by scheduling washing machine, tumble drier, slow cooker etc etc to be on during the day when its bright. Do one after the other to minimise grid draw and max your self use...........but you know all this already so no one really needs to be repeating it??? Just put self installed on the G98, that's all my son in law did and all I did on our G99. Rest of the stuff is inverter details and if you've done electrical work you'll understand all that. Apparently the ENA estimates that less than 50% of PV install has been notified to DNOs so they'll probably be quite greatful of your notification Whilst we have a washing machine, during the day in summer, theres minimal demand and nothing to move to that time. Even my workshop is very light on demand in the summer months. Im going to be putting it into the grid rather than using most of it, then buying it when i need it. Yes, i will be saving at least some cost, so theres logic in your argument, but essentially id be wasting a lot of it. Which seems a shame I think Johnmo has demonstrated even in winter, with panels optimised to suit, (which i would do) useful amounts of energy can be collected. Ultimately my demand is high in winter, especially when its dark, near non existent in summer. Excarbated by high workshop power use in winter also. And i really want simple. I know, you probably think thats weird, but if i cant install and maintain it myself, then im not going to do it.
Crofter Posted 30 minutes ago Posted 30 minutes ago @Roger440 how much of the gear have you already bought? The only way to guarantee no benefit is to leave it uninstalled. Just because you can't get the optimum use out of it doesn't mean it's pointless. You have to install the panels etc eventually, might as well do it now and you'll offset a bit of energy. And you can feel smug because you're doing your bit to help decarbonise the grid. 1
