Hi all, a steer, please?
I have had a chat with my builder, as I felt the cavity & ties were not clean enough.
 - He agreed that the ties should be cleaner, and was agreeable.
 - He felt that because there is a 150mm (min, but 175mm mostly) drop in the DPC from inner leaf to outer leaf, that it is OK to have a small amount. I told him that I had sent pictures to the (sick, but doing some work) architect for her view, and he said that she will say they should be clean, but that is simply not practical.
Obviously, I pay her to keep standard up, but am mindful that the builder may have a point, on practicability - thoughts? To make my question more direct - is 25mm of droppings in a 150/175mm DPC OK, or do I need to insist on a clean? Likewise, I could just rock in, and demand my "rights", but I feel there is good value in keeping an amenable builder happy!
That doesn’t look bad at all
Tell him to go round and give the ties a rattle Then we are good
He will know what you mean
  • Like 3
Not sure that the idea of 'one discipline versus another is helpful . The architect probably hasn't ever lifted a trowel or dried out a wet wall, or the builder had to create a scale drawing or buy a decent pair of trousers to go to work.
Trades and professions often 'dis' one another - especially when they are on your payroll. I got really fed up with that.
If you want them cleaned, get them cleaned . If they won't, then DIY.
If you don't, you'll be watching the bottom of your walls for water marks for ever and a day.
  • Haha 1
Plus one to this. That’s fine
If someone posted pics of a ‘messy’ cavity, you’d see that this guy is actually working to keep the cavity clean.
Architect will just repeat what is written in the guidelines, but most architects can’t build a house. Each to their own.
You’ve nothing to worry about here, and I’d go tell the builder what you’ve been told about his work. There will be a cloud hanging over him otherwise. Nothing worse than that.
  • Like 2
Mmh, I thought I responded to this post, so if Im repeating myself...
Thanks all - good points. As always, I really appreciate you taking the time to share your views. All good here.
If there are more of these you could get the bricklayer to leave a couple of blocks out so you can clean the cavity.
Often there is no cavity tray at the bottom, just separate DPCs
