Sam11 Posted June 20, 2023 Posted June 20, 2023 Hi all can anyone explain the name of this feature, whereby the font door panel seems to extend above the door and exterior wall above. I have a normal canopy porch and would like to get rid of this and install a feature like this. Is there a particular name for this from an architectural perspective. Is there any structural works required. Any insight would be much appreciated.
Temp Posted June 20, 2023 Posted June 20, 2023 Welcome to the forum, if you find it useful consider donating to server costs.  These are sometimes called "full height" doors or windows. Normally used where the ground floor inside also extends upto the roof, perhaps the stair we'll, but not necessarily. 1
Temp Posted June 20, 2023 Posted June 20, 2023 As for structural work it might depend on what you have inside. Does the first floor meet the front wall above the current front door or do you already have a stair well? Which way do the floor joists run? Front to back or left right? A lintel is also needed above the top window. 1
Sam11 Posted June 20, 2023 Author Posted June 20, 2023 Many thanks. My own house has a window above the front door with brick wall in between the two. Both the door and window above share the same structural wall so I think is doable. We have stairs in front when you open the door so would like to have this feature to form part of the landing.  Below is my own front door with a standard canopy porch. I would like to get rid of the bulk and create a more streamlined look to the house exterior.
ETC Posted June 20, 2023 Posted June 20, 2023 2 hours ago, Sam11 said: Hi all can anyone explain the name of this feature, whereby the font door panel seems to extend above the door and exterior wall above. I have a normal canopy porch and would like to get rid of this and install a feature like this. Is there a particular name for this from an architectural perspective. Is there any structural works required. Any insight would be much appreciated. I think it’s called 80’s post modern too high to clean or do anything with.
Canski Posted June 20, 2023 Posted June 20, 2023 You may find that you have block instead of brickwork on the cheeks behind the roof. 1
Sam11 Posted June 20, 2023 Author Posted June 20, 2023 (edited) Thank you for the feedback. Yes this could be the case. You never quite know what you are working with until you start taking things apart. Edited June 20, 2023 by Sam11
Sam11 Posted June 20, 2023 Author Posted June 20, 2023 1 hour ago, ETC said: I think it’s called 80’s post modern too high to clean or do anything with. Ahh the 80s. Reagan, Thatcher the Cold War between east and west, and Spandeu Ballet.Â
Radian Posted June 20, 2023 Posted June 20, 2023 4 hours ago, Sam11 said: Below is my own front door with a standard canopy porch. Does it never rain where you live?😅 1 1
Gus Potter Posted June 20, 2023 Posted June 20, 2023 You could find an absolute mess behind that canopy and never get it to look ok. Â If you want to get light in can you do anything at roof level, say by way of some kind of light well, glazing panel? 1
