SteveH2 Posted June 20, 2023 Posted June 20, 2023 Our installations dates from 2009, the installer is no longer in business. On a sunny day it runs at 1500W or more. Now it's dropped to 400Wish. The panels are reasonably clean A local outfit says it will be the inverter (price to replace nearly 2K), but that sounds unlikely to me. Could it be, are there any other possibilities? Thanks
SteamyTea Posted June 20, 2023 Posted June 20, 2023 (edited) Moe details of your system are going to be needed. Is there an off chance that a tree has grown and is now shading the modules. Edited June 20, 2023 by SteamyTea
Temp Posted June 20, 2023 Posted June 20, 2023 Could be the inverter or the panels. On some old systems shading or a defect on just one cell in one panel limits the output of the whole system. Needs someone to look at it on a sunny day not just guess from their office.
PhilT Posted June 20, 2023 Posted June 20, 2023 Did this happen suddenly just now? What are you reading from? Are you able to corroborate app data with solar generation meter and a rough idea from whatever mains/export meter setup you have? I had a glitch once due to a CT clamp being knocked out of position
Alan Ambrose Posted June 20, 2023 Posted June 20, 2023 I think that inverters are generally of the 'fails fully or not at all' variety of equipment. I suggest a single panel could be damaged or something more subtle. Check connections carefully and see if anything is hot that shouldn't be. Scan the roof with binoculars etc. And yeah, you need to provide more information... Output slowly reduced over many months? Suddenly dropped one day? Multiple strings? How many panels? Any shaded? Graphs, pictures etc. We're not clairvoyant you know...you need to do some of the work too.
SteamyTea Posted June 20, 2023 Posted June 20, 2023 (edited) 5 minutes ago, Alan Ambrose said: Check connections carefully and see if anything is hot that shouldn't be But not with bare hands. Especially iny the DC side, the black cables. Edited June 20, 2023 by SteamyTea
Dillsue Posted June 20, 2023 Posted June 20, 2023 4 hours ago, SteveH2 said: A local outfit says it will be the inverter (price to replace nearly 2K), but that sounds unlikely to me. Could it be, are there any other possibilities? Post a photo of the inverter and its data plate. Do you know the make and model of the panels and how many there are?
SteveH2 Posted June 21, 2023 Author Posted June 21, 2023 On 20/06/2023 at 13:59, SteamyTea said: Moe details of your system are going to be needed. Is there an off chance that a tree has grown and is now shading the modules. Definitely not, but thanks
SteveH2 Posted June 21, 2023 Author Posted June 21, 2023 On 20/06/2023 at 14:19, PhilT said: Did this happen suddenly just now? What are you reading from? Are you able to corroborate app data with solar generation meter and a rough idea from whatever mains/export meter setup you have? I had a glitch once due to a CT clamp being knocked out of position I wish I knew if it was sudden (but see below). From the display on the inverter. Not an app.
SteveH2 Posted June 21, 2023 Author Posted June 21, 2023 Setup. 14 BP 180WC panels, Fronius IG30 inverter. I managed to find the manual for the inverter online. There was a hint that it can reduce the output if it overheats. I turned it off, gave it 10 minutes, turned it on again, and the output climbed to a plausible level (1300W today). Then sunk down to 400Wish. There is an interior fan which isn't turning. If only the local agent responded to messages Thanks
SteveH2 Posted June 21, 2023 Author Posted June 21, 2023 On 20/06/2023 at 14:23, Alan Ambrose said: I think that inverters are generally of the 'fails fully or not at all' variety of equipment. I suggest a single panel could be damaged or something more subtle. Check connections carefully and see if anything is hot that shouldn't be. Scan the roof with binoculars etc. And yeah, you need to provide more information... Output slowly reduced over many months? Suddenly dropped one day? Multiple strings? How many panels? Any shaded? Graphs, pictures etc. We're not clairvoyant you know...you need to do some of the work too. see my post at around 15:30 today Yes exactly I was thinking inverters would be all or nuthin, but actually overheating protection makes sense. Can't say for sure when output dropped over how long, but suspect it's sudden because I think I would have noticed. Roof looks fine we can get at it easily. No shade. 14 panels BP brand 180WC, grouped as 10 and 4, Fronius IG30 inverter Thanks
Conor Posted June 21, 2023 Posted June 21, 2023 A replacement inverter won't cost you £2k. Are you tied to a payment scheme that dictates what can be altered in the system? If not, a new inverter will be ~£500 and a couple of hours to install. But as you say, could be something as simple as a fluff clogged fan or burnt out motor.
Dillsue Posted June 21, 2023 Posted June 21, 2023 6 hours ago, SteveH2 said: Yes exactly I was thinking inverters would be all or nuthin, but actually overheating protection makes sense. Take the cover off the inverter and leave a fan heater set to cold blowing over the innards to cool it down. Make sure no one can touch the inverter when its powered or for 10 mins after its switched off!! Turning it off for a short while isnt going to cool it much so if overheating is your problem it'll be unlikely youll make any difference turning it off and on. If the inverters duff theres unlikley to be any reason not to fit a modern inverter, the FIT scheme now allows you to change components/system size.
markocosic Posted July 20, 2023 Posted July 20, 2023 How long left on fit? I'd you can get a bigger energy density setup installed (more watts per M2) it may well pay to replace the lot; aiming for 4kW(peak) panels on a 3.6kW(peak) inverter...
