Tim H Posted June 14, 2023 Posted June 14, 2023 Hi all, Firstly, apologies if this is a stupid/naive question. I've been looking at 'wall starter' kits to try and understand how to use them on a single skin wall that we need to rebuild. I have seen a YouTube video published by Toolstation for a BPC kit. There is a section that states "The vertical joint between the existing wall and the outer leaf of the new wall must be weathersealed either with pre-compressed sealing strip or polymer based pointing". I've searched Google and can find some admixes (SBR, etc) that I'm guessing it's required to create 'polymer based pointing'. So my questions are, what is 'polymer based pointing'? Is it just a normal mortar mix with a polymer additive, and scan anyone recommend any products that they've used successfully? Thank you.
joe90 Posted June 14, 2023 Posted June 14, 2023 14 minutes ago, Tim H said: Firstly, apologies if this is a stupid/naive question. No such thing as a stupid question, stupid is not asking and making (wrong) assumptions 😎, I guess they are talking about silicone type polymer (using a gun like decorates caulk etc) but more informed people will be along in a mo.
Discoeye Posted June 14, 2023 Posted June 14, 2023 (edited) Or look at Tremco compriband or similar expanding joint tape. As stated by Joe90 there will be more wise minds to give advice. Edited June 18, 2023 by Nickfromwales
Tim H Posted June 15, 2023 Author Posted June 15, 2023 Thank you both. Joe90 - Thank you for the kind reply. I did initially wonder whether they meant to use an external frame sealer or similar, but I wasn't sure. Discoeye - I've Googled Tremco tape and it looks like that could be a good option. Thank you.
Dave Jones Posted June 15, 2023 Posted June 15, 2023 if your bricking it up you can just morter the joint. will look better.
Tim H Posted June 15, 2023 Author Posted June 15, 2023 Thanks Dave. Would I use a normal mortar mix or should I include a polymer admix?
SteamyTea Posted June 15, 2023 Posted June 15, 2023 20 hours ago, Tim H said: So my questions are, what is 'polymer based pointing Polymer cement mortar Edit Polymer cement mortars (PCM) are the materials which are made by partially replacing the cement hydrate binders of conventional cement mortar with polymers. The polymeric admixtures include latexes or emulsions, redispersible polymer powders, water-soluble polymers, liquid thermoset resins and monomers.[16] Although they increase cost of mortars when used as an additive, they enhance properties. Polymer mortar has low permeability that may be detrimental to moisture accumulation when used to repair a traditional brick, block or stone wall. It is mainly designed for repairing concrete structures. The use of recovered plastics in mortars is being researched and is gaining ground.[17] Depolymerizing PET to use as a polymeric binder to enhance mortars is actively being studied.[18][19][20] 1
Canski Posted June 15, 2023 Posted June 15, 2023 We usually just mortar them. Very occasionally we are asked to debond the ties and provide a movement joint. Don't overcomplicate it 🙂
Tim H Posted June 18, 2023 Author Posted June 18, 2023 Thank you all for your replies. I really appreciate all of your input.
Brickie Posted June 18, 2023 Posted June 18, 2023 I prefer a mastic joint there-we’ve all done them in mortar & a hairline crack is usually the result. 2
Mr Punter Posted June 18, 2023 Posted June 18, 2023 I have used Sikaflex EBT for this. You need to be careful not to smear it everywhere but it is a good product.
