Dave Jones Posted May 7, 2023 Posted May 7, 2023 some say a nails width gap? Our last build had a large flat (warm) parapet roof (10x6), i butted the OSB (cheaper than ply) up tight and had zero squeaks, movement.
gc100 Posted May 7, 2023 Posted May 7, 2023 Thermal expansion looks very minimal https://www.performancepanels.com/dimensional-stability-flatness#:~:text=Plywood and wood expand upon,exacting techniques for its measurement. as someone who built a few skateboard half pipes out of ply , I’ve never seen it buckle and that’s exposed to the elements
Adsibob Posted May 7, 2023 Posted May 7, 2023 With OSB, we were advised by our liquid roof membrane supplier (that was poured onto the osb) to leave a 1mm expansion gap. But maybe plywood is more stable than osb.
Iceverge Posted May 7, 2023 Posted May 7, 2023 @Patrick used closely spaced boarding instead of ply which I prefer TBH as any moisture under the Zinc has somewhere to dry to.
