CalvinHobbes Posted May 1, 2023 Posted May 1, 2023 Hiya, there is a 3 phase pole behind us which is being moved but in addition we need a connection off it for the 2 houses. I was reading the technical sheet they sent out, it said "The supply will be alternating current having a declared voltage of 230 Volts, single phase and neutral with a frequency of 50 hertz" will that do? Thinking of charging an electric car as well as running the house. Like is that the biggest connection you can get without going 3 phase?
ProDave Posted May 1, 2023 Posted May 1, 2023 What you need to know is the power rating of the supply, usually expressed in KVA Which is thousand Volts times Amps which for all practical purposes the same a kW (thousand Watts) Ask them. 1
CalvinHobbes Posted May 1, 2023 Author Posted May 1, 2023 55 minutes ago, ProDave said: What you need to know is the power rating of the supply, usually expressed in KVA Which is thousand Volts times Amps which for all practical purposes the same a kW (thousand Watts) Ask them. Thanks I deffo will, just to firm up what I am asking from the customer proposal map it looks like a red line which appears to be 11KV, does that sound like it? What should I be aiming for? The planner fella a while back on the phone indicated he would do the best he could for us and would use a thicker wire. (He obviously didn't use that terminology lol).
dpmiller Posted May 1, 2023 Posted May 1, 2023 Is there a pole transformer or a "substation" in the vicinity? 1
ProDave Posted May 1, 2023 Posted May 1, 2023 If it's an 11KV cable there, then you will need a transformer, and the size of that will dictate the amount of power available. 1
