Chimney
Terrible brick / block work and somebody has tried to fill in the gaps with expanding foam. Worst chimney stack I've ever seen.
Context? Own / buying / viewing? How old is it and is that an external wall or a party wall?
If that is indicative of the quality of the rest of the work in the build, I'd run a mile.
The only time I have seen a chimney rendered like that (though usually at least smooth!!!!!) is following damage from a chimney fire.
Is the foam just a crude attempt at blocking air and possibly smells coming through from stinky neighbours?
