Water main location
Does anybody know how to locate a water main.
Main is plastic and 50mm pipe so carries a lot of water I need to install a new electric cable and really could do without digging up the water main.
The pipe is on my property so water authority have no plans or give a monkeys.
Cheers russ.
54 minutes ago, Russell griffiths said:
Divining has been mentioned but with all the water around me and in the ground I think it's a non starter.
You would think the manufacturer would be on to this and start installing a trace wire thingy in the pipes by now.
It's now best practice to install a trace wire alongside a plastic pipe.  The wire can be connected to a signal generator and use to create a field that a CAT can detect.  If laying a new long length of underground pipe it makes sense to add a trace wire, just to ease the hassle of anyone trying to find it later.
Edited by JSHarris
