Kernow Posted March 13, 2023 Posted March 13, 2023 Starting to think about getting insulation down ready for screed. we have the following floor build up: 100mm reinforced slab 140mm pir 60mm liquid screed porcelain tiles floor covering Question is will the screed/insulation be strong enough to take the staircase and newel post weight or will added support be required? Just a standard staircase, nothing fancy. If it needs supporting what’s the best way to be this? Replace PIR with something like an XPS500 or is there an alternative solution? Thanks
Redoctober Posted March 13, 2023 Posted March 13, 2023 @Kernow I don't know for sure but would have thought any additional support - if required - would have been factored into the plans / building notes. This is a list of our floor build up from the top down and have had no issues with our staircase. limestone tiles - 22mm 65mm self leveling sand/cement screed · 100mm Kingspan Thermafloor TF70 (or similar and approved) rigid insulation board. 150mm thick concrete slab designed by engineer.
markc Posted March 13, 2023 Posted March 13, 2023 Unless you are intending a massively heavy single spine staircase then you have nothing to worry about. let’s assume the staircase weighs 100kgs plus 2 people at 100 kgs each, total 300;split between 2 stringers so each stringer (foot or wall mounted) takes 150 and that is split between top and bottom (unless both people are on the bottom step). now take a 3 seater sofa with 3 people, say 350kgs split between 4 legs. The loads are fairly similar and you wouldn’t worry about the sofa.
Kelvin Posted March 13, 2023 Posted March 13, 2023 Our staircase is supported by two thickening points in the concrete slab. Still not 100% confirmed how we’ll build this up but probably with blocks.
Mr Punter Posted March 13, 2023 Posted March 13, 2023 I have had an engineer spec some special grout under the newel of a stair in a commercial building. I didn't bother doing it as the floor was concrete and the stair was only timber.
