Adam2 Posted February 24, 2023 Posted February 24, 2023 I've seen the earlier threads on this topic and note that there seems to be a few places where it is stated that 12.5mm standard plasterboard alone (well obviously not alone but fitted to something like an MF ceiling) is sufficient for 30 mins fire protection. I've had a look to find a reference for this but am unable to. Would be greatly appreciated if anyone could provide one that I could use to support some discussions with BC.
nod Posted February 24, 2023 Posted February 24, 2023 If your over three floors your steels will need protecting At least one layer of 15 mil fb MF ceiling trim will give you the required void
ETC Posted February 24, 2023 Posted February 24, 2023 Check out the British Gypsum White Book before you do anything. You can’t just clad structural steel in plasterboard unless you follow the manufacturer’s installation instructions. https://www.british-gypsum.com/specification/white-book-specification-selector. For houses you will need 30 minutes fire resistance for all elements of structure except for a party/separating wall between dwellings which should be 60 minutes. 1
nod Posted February 24, 2023 Posted February 24, 2023 37 minutes ago, ETC said: Check out the British Gypsum White Book before you do anything. You can’t just clad structural steel in plasterboard unless you follow the manufacturer’s installation instructions. https://www.british-gypsum.com/specification/white-book-specification-selector. For houses you will need 30 minutes fire resistance for all elements of structure except for a party/separating wall between dwellings which should be 60 minutes. Unless the house is over three floors All GF steel will need protection
ETC Posted February 24, 2023 Posted February 24, 2023 All structural steel - not just that on the ground floor - will need fire protection.
Adam2 Posted February 25, 2023 Author Posted February 25, 2023 Thanks for the replies, I'm aware of the need for protection. My question was is there any reference source for the claims that have been made on other threads relating to standard plasterboard providing 30 mins protection?
Mr Punter Posted February 25, 2023 Posted February 25, 2023 15 hours ago, ETC said: What happens to a house over three floors? I think it would need 60mins protection, so 2 layers 15mm or 2 layers 12.5mm fireline.
SteamyTea Posted February 26, 2023 Posted February 26, 2023 Why not go for 60 minutes or better if you can. Sometimes minimum standards are a hazard in themselves.
