Hi,
I'm trying to sort out the water main, 32mm MDPE, and for some reason I can't find any insulation to suit the pipe. I bought the Shalloduct product to then find that it is completely rigid and basically useless. The only product I can find on the web is the below, but I can only find it stocked in one builders merchant in Lancashire and they don't deliver!
How have others dealt with this? Thanks
Pre-Insulated Blue Ducting Bend for 32mm MDPE Pipe - 1.5 Metre x 4"
I don’t think I’ve ever seen an insulated water main. The water pipe from my borehole isn’t insulated. I’d have thought as long as it’s deep in the ground it won’t ever freeze and when it enters the building it will always be above freezing.
Hi - this is what we used - for our temporary standpipe insulation.
SHalloduct Water Service Pipe Insulation - 835 x 32mm - 19170 (bes.co.uk)
110mm Blue Twinwall Duct x 3m inc coupling (tradepipes.co.uk)
It was a bit tricky to bend in a hockey stick shape, but we did manage to manipulate it into position with the help of some metal straps.
Edited by deancatherine09
