7 minutes ago, Thorfun said:
doesn't give any sort of sound reduction values though.
๐Ÿ˜Ž minor point! - website is (expletive deleted)ed anyway! ; I can't order even if I wanted too. I'll keep looking!
16 minutes ago, pocster said:
Maybe ?
ย
https://thermalinsulationonline.co.uk/shop/pipe-section/rockwool-pipe-insulation-sections/
ย
It is in essence just rockwool ( so no sound spec ) but saves boxing in.....
rockwool is good for sound insulation so this might be a good choice. 25mm thick x 108mm pipe size is ยฃ10.82/m exc VAT. I guess it all depends on how thick you want it. our heating engineers used this type of stuff for our ASHP flow and return internally.
Yeah itโ€™s probably the best . Shipping was a flat rate of ยฃ15 .ย
I went for it in the end . 6m ; 114mm pipe ; 50mm thicknessย
good job. will be interested in how it works. don't gorget to keep detailed data from you testing using the correct units to keep @SteamyTea happy.
Iโ€™m going to use my phones decibels measuring app at discreet points along the pipe ( mainly where wc enters ) . Get some readings before and after lagging .
3 minutes ago, pocster said:
Iโ€™m going to use my phones decibels measuring app .....
ย
I know, lets all do a comparative table: get our respective OHs to perform, send the results to @SteamyTeaย - who would anonymise the results , work his Excel Magic and then publish them.ย
Would I (expletive deleted). We all want to know whose missus trumps the loudest, and highest pitch.
ย
So we have to listen to your shit ? ๐Ÿ™‚
No ! Just flushing an empty loo max db ๐Ÿ˜
  • 3 months later...
