Noise proof my πŸ’© pipe
Pocster
1 minute ago, pocster said:
Right!
Β
https://insulationandlagging.co.uk/Acoustic-Insulation/Acoustic-Insualtion-Pipe-Wrap/Acoustilag-Acoustic-Pipe-Lagging
Β
With sensible delivery cost. I need 6m ; but 1 roll does 4.8m around a 110mm pipe - so I'll need to stretch it a bit. Maybe acoustic lag mainly at junctions of pipes?
doesn't give any sort of sound reduction values though.
16 minutes ago, pocster said:
Maybe ?
Β
https://thermalinsulationonline.co.uk/shop/pipe-section/rockwool-pipe-insulation-sections/
Β
It is in essence just rockwool ( so no sound spec ) but saves boxing in.....
rockwool is good for sound insulation so this might be a good choice. 25mm thick x 108mm pipe size is Β£10.82/m exc VAT. I guess it all depends on how thick you want it. our heating engineers used this type of stuff for our ASHP flow and return internally.
Yeah it’s probably the best . Shipping was a flat rate of Β£15 .Β
I went for it in the end . 6m ; 114mm pipe ; 50mm thicknessΒ
good job. will be interested in how it works. don't gorget to keep detailed data from you testing using the correct units to keep @SteamyTea happy.
I’m going to use my phones decibels measuring app at discreet points along the pipe ( mainly where wc enters ) . Get some readings before and after lagging .
So we have to listen to your shit ? πŸ™‚
  • 3 months later...
