CalvinHobbes Posted January 16, 2023 Posted January 16, 2023 Just looking at the weather forecast and trying to work out timings. Cottages came down today - it was thrilling. An 8 tonne digger made mincemeat of them. [Mod note: I've merged the two threads on the same topic, so responses might seem to not quite follow on as you remember. The duplicate post (this one with photos) is a few posts down]
Thorfun Posted January 16, 2023 Posted January 16, 2023 1 minute ago, CalvinHobbes said: Just looking at the weather forecast and trying to work out timings. Cottages came down today - it was thrilling. An 8 tonne digger made mincemeat of them. any photos? Timelapse video? everyone loves to see stuff being smashed up! 1
George Posted January 16, 2023 Posted January 16, 2023 5 degrees usual limit, 3 degrees air temp absolute minimum. Main things are is that the concrete itself is over 5 degrees, the ground isn't frozen, that temperatures are rising when you pour and you have a way to protect the pour from frost. 10:30 is a good target time if the site gets the sun. Blockwork you can start 48 - 72 hours after. If there are points loads should be waiting for at least 7 day cure time. Build plenty of slack into the programme for path critical things... 1
CalvinHobbes Posted January 16, 2023 Author Posted January 16, 2023 (edited) Edit to add the requested pics,the last one is obviously from today. Wood etc was stripped before it was tumbled, I had it boarded over christmas because I was concerned a child could get in. The last pic was at the end when the discussion was re the fill and considering levelling up the garden at the front. Up to now you would need a rope on your back when using a lawnmower. The old driveway was to the front left but you would need a tractor to get up it. Total clutch wrecker. I will try and pull some footage too. Edited January 17, 2023 by jack Merging... 1
nod Posted January 16, 2023 Posted January 16, 2023 As with bricklaying and plastering 3 and rising Many company will pour around 0 1
Thorfun Posted January 17, 2023 Posted January 17, 2023 9 hours ago, CalvinHobbes said: The last pic was at the end when the discussion was re the fill and considering levelling up the garden at the front. Up to now you would need a rope on your back when using a lawnmower. The old driveway was to the front left but you would need a tractor to get up it. Total clutch wrecker. That’s some plot! Well done. I look forward to following your journey. thanks for the photos. I can’t wait until we’re finished and can demolish our bungalow. 1
bmj1 Posted January 17, 2023 Posted January 17, 2023 Very exciting! I'm afraid it takes a little longer to go up... Hope all continues to go smoothly for you 1
CalvinHobbes Posted January 18, 2023 Author Posted January 18, 2023 Thank you, 2 homes are going up there. One for my family with a granny flat and the other for my sister. We have lived in the neighbourhood for years and the neighbours are lovely. 1
LSB Posted January 22, 2023 Posted January 22, 2023 spoke to concrete supplier this week, they will poor at whatever the temperature is, if you ask, but you have to 'signoff' the risk if temp is lower than 2 degrees
