Hi! I would like to replace my existing patio with porcelain tiles or sandstone tiles. A friend suggested I tile over the existing pavers but I don’t feel that is the right way to do it - several of them are loose/ wobbly and a couple are cracked. If I lift them all up I’m left with dirt as shown in the picture.
my idea would be to compact the dirt with a plate compactor, lay mortar, prime the tiles and lay - would this be ok? Or should I lay mortar on top of the existing pavers?
Thanks in advance
David
Like everything else it’s all in the prep. Get the base layer right and you won’t have wobbly tiles/slabs a few years down the line
33 minutes ago, Andehh said:
then full mortar base on top.
^^^ Important advice that. Don't copy the way the old slabs were laid by plonking them down on dollops of mortar. It's a terrible shortcut that has all kinds of bad repercussions.
We need a 2m-3m strip around the house to enable the kit erection so intend to build up the area that will be patio in readiness
Porcelain will be very slippy when wet. Also make sure any tiles are suitable for cold weather as well as nonslip.
I have observed paving laying differences uk and Spain.  You don't see a lot of cracks and potholes in a spanish street or square because of 1. The weather. But 2. Because under the tiles is a  reinforced concrete slab, suitable for forklifts. But good builders do the same in domestic situations too.
Therefore as above...dig out some more ground, lay compacted stone. Then I would lay a concrete slab with mesh, 70 thick. Then the tiles or slab are a finish. All on a slope.
If you want, you can break up the existing material small,  to use as hard-core on the bottom.
I'd disagree with porcelain being slippy when wet. I paved a large patio at my previous house in porcelain slabs and it wasn't slippy at all.
