Hargrid Posted January 12, 2023 Share Posted January 12, 2023 Hi, Looking to install MVHR and an air source heat pump to run the underfloor heating. Any recommendations for suppliers and installers? I have approached Total Home Environment who do the full package using NU Heat for the UFH. Any other companies to consider? Link to comment Share on other sites More sharing options...
Conor Posted January 12, 2023 Share Posted January 12, 2023 MVHR nothing to do with UFH or ASHP so don't be going to a single supplier. Is this a new build or renovation? Lots of factors to consider and it helps to have as much as possible detailed before speaking to different suppliers so you can better compare and contrast quotes. 1 Link to comment Share on other sites More sharing options...
Hargrid Posted January 12, 2023 Author Share Posted January 12, 2023 2 hours ago, Conor said: MVHR nothing to do with UFH or ASHP so don't be going to a single supplier. Is this a new build or renovation? Lots of factors to consider and it helps to have as much as possible detailed before speaking to different suppliers so you can better compare and contrast quotes. Hi Conor I do realise it's not all part of the same system. It's a new timber frame build so I am just investigation the various options and Total Home Environment can provide the whole package. That said I am keen to get various quotes to compare as I know roughly the spec I need to install. I got a quote from one ASHP supplier, they don't have good reviews and almost immediately tried to sell me a system on credit which I don't want! Link to comment Share on other sites More sharing options...
Bramco Posted January 12, 2023 Share Posted January 12, 2023 Renewable energy companies are the new double glazing salesmen...... Lot's of sucking of teeth etc. If it's new build make sure that you get the Boiler Upgrade Scheme £5k - sounds crazy but it does apply to self builds as well as replacing existing boilers. We had our main contractors do the insulated slab and the DHW tank and UFH buffer tank - both with double immersions. Only after that did we install the ASHP and that was basically because it cost us £200 with the BUS grant. So do all the heat loss analysis etc. and only put in what is absolutely necessary. MVHR is, as Conor said completely separate - you should be able to find an MVHR expert in the area and I'll bet they'll be a lot cheaper than your chaps that can do it all. Simon 1 Link to comment Share on other sites More sharing options...
HughF Posted January 13, 2023 Share Posted January 13, 2023 (edited) Pay £8k more than you need too to save £5k through the BUS? Not the way I’d go but each to their own. Have you got a heat load for the property yet? That’s the first port of call. Edited January 13, 2023 by HughF 1 Link to comment Share on other sites More sharing options...
PeterW Posted January 13, 2023 Share Posted January 13, 2023 17 hours ago, Hargrid said: Any other companies to consider? Supply or supply and install..?? Link to comment Share on other sites More sharing options...
SBMS Posted January 13, 2023 Share Posted January 13, 2023 (edited) On 12/01/2023 at 14:32, Hargrid said: Hi, Looking to install MVHR and an air source heat pump to run the underfloor heating. Any recommendations for suppliers and installers? I have approached Total Home Environment who do the full package using NU Heat for the UFH. Any other companies to consider? We used total home to design and supply our MVHR and our builder has installed it. I believe that total home subcontract our the install. They were really very good, worked with us through a design change when we went with trusses and have been very useful and communicative. Edited January 13, 2023 by SBMS Link to comment Share on other sites More sharing options...
