jayc89 Posted January 4, 2023 Posted January 4, 2023 I have a wall that goes from 2 bricks wide to 1 brick wide half way up a room. I want the finish flush. Can I stud from the lip, finishing the top half in plasterboard and the bottom half in wet plaster direct to the wall. Or is it better to stud the full wall and PB it all? If the former, I assume the PB would need to protrude a few mm from the bottom half wall, to allow for a base coat of hardwall on the brick, before a multi-finish coat across the lot?
ProDave Posted January 4, 2023 Posted January 4, 2023 That's an odd arrangement. I would first be asking does the wall need or would benefit from extra insulation? This is the once chance you get to easily add insulation before proceeding so think about that first.
jayc89 Posted January 4, 2023 Author Posted January 4, 2023 (edited) 4 minutes ago, ProDave said: That's an odd arrangement. I would first be asking does the wall need or would benefit from extra insulation? This is the once chance you get to easily add insulation before proceeding so think about that first. It's an odd part of the house Watching trades try get their head's around doing any work around this area is quite amusing. The 2 brick thick part used to be the cellar (which was only approx 500mm below ground level), which has since been beam + blocked over. The 1 brick thick part was a bathroom on the half landing. We now have a single room at ground level. It's an internal wall, the other side is the staircase, so doesn't need 100mm+ insulation adding. Edited January 4, 2023 by jayc89
ProDave Posted January 4, 2023 Posted January 4, 2023 I would personally plasterboard the lot and then skim it. anything else is asking for a crack to appear where the upper plasterboard meets the lower plastered brick. 1
Nickfromwales Posted January 4, 2023 Posted January 4, 2023 Timber frame the top half to be 15mm proud of the proudest part of the lower wall, then affix full boards, screwing the upper and dabbing the lower 1
jayc89 Posted January 4, 2023 Author Posted January 4, 2023 I'm going to need a new door casing as well, aren't I?
Mr Punter Posted January 4, 2023 Posted January 4, 2023 You could have a wainscoting / panelled look with a shelf which may look good or a bit naff.
