Canski Posted January 30, 2023 Posted January 30, 2023 7 minutes ago, ruggers said: My joists are going on internal masonry hangers. Door and window reveals say they need a wall tie every 225mm so they'll need slit to. Tada !! yes they need to be slit too. More delamination 1
Mr Punter Posted January 31, 2023 Posted January 31, 2023 I have used full fill rigid t&g insulation before. It was often a struggle to get the bricklayers to fit them the correct way up. Luckily it was just ground floor with timber frame and cladding above so not so much hassle with coursing. 1
Dave Jones Posted January 31, 2023 Posted January 31, 2023 best bang for your buck buildup. Use EPS under the screed not far from half the price of celotex for a superior U value. Here is what we use working FFL down. external Internal damp damp 75mm eng 75mm screed 75mm eng 225mm 7n block 300mm EPS insulation 225mm 7n block 150mm beam 75mm conc common total build up 600mm / 600 dont forget to use thermally broken marmox blocks as the first course of inner skin. 1
ruggers Posted February 6, 2023 Author Posted February 6, 2023 @Dave JonesThanks Dave, whats the difference with the marmox blocks and a celcon/aircrete/thermalite block for the first course? I was going to run a course of them round before I build my inner walls with normal block on top. The marmox looks very expensive. I had a look at EPS and I'd need 240mm to equate to 160/165mm PIR. The saving was £700 but by the time I'v bought the extra course of bricks and paid the labour it just works out the same.
MikeGrahamT21 Posted February 6, 2023 Posted February 6, 2023 1 hour ago, ruggers said: @Dave JonesThanks Dave, whats the difference with the marmox blocks and a celcon/aircrete/thermalite block for the first course? I was going to run a course of them round before I build my inner walls with normal block on top. The marmox looks very expensive. I had a look at EPS and I'd need 240mm to equate to 160/165mm PIR. The saving was £700 but by the time I'v bought the extra course of bricks and paid the labour it just works out the same. Marmox Thermoblocks are essentially XPS with concrete reinforcement in them, where aircrete blocks are 0.11W/mK marmox is 0.047W/mK https://www.marmox.co.uk/products/thermoblock 1
ruggers Posted February 6, 2023 Author Posted February 6, 2023 Thanks a big difference in U-Value, I wouldn't mind a house built from them if I wasn't paying for it.
MikeGrahamT21 Posted February 6, 2023 Posted February 6, 2023 Isn't that just a house constructed from SIPS or ICF? 😂
ruggers Posted February 6, 2023 Author Posted February 6, 2023 I didn't think sips was that low, thought it's just PIR of a certain thickness in structural panels for fire it up quick. I've never looked into it much due it it being fairly expensive but I think it's a great way to build if you can afford it.
