saveasteading Posted December 8, 2022 Posted December 8, 2022 screwfix £1.07.. Just check the dimensions.
ProDave Posted December 8, 2022 Posted December 8, 2022 they come in different lengths, measure the distance from the face of the door to the centre of the hole which the square spindle goes through and buy the same length. 1
zoothorn Posted December 8, 2022 Author Posted December 8, 2022 52 minutes ago, ProDave said: they come in different lengths, measure the distance from the face of the door to the centre of the hole which the square spindle goes through and buy the same length. Fantastic- never thought it would be this simple in a month of sundays. Will do- thanks chaps.
zoothorn Posted December 8, 2022 Author Posted December 8, 2022 1 hour ago, saveasteading said: screwfix £1.07.. Just check the dimensions. Bloomin marvellous! Hope to heck one will fit. Thanks SAS
markc Posted December 8, 2022 Posted December 8, 2022 You will find one to fit, have had a few recently that were measured (and stated) assistance to back of face plate when it’s generally face of face plate (flush with door edge)
zoothorn Posted December 10, 2022 Author Posted December 10, 2022 On 08/12/2022 at 11:55, ProDave said: they come in different lengths, measure the distance from the face of the door to the centre of the hole which the square spindle goes through and buy the same length. ProDave, is this distance from face to hole you refer to here, called the "Backset Size" ? ThankZ
ProDave Posted December 10, 2022 Posted December 10, 2022 Yes I believe the case length is overall length, how deep the hole in the door needs to be, and backset is distance fromt he door edge to the centre of the spindle.
zoothorn Posted December 11, 2022 Author Posted December 11, 2022 18 hours ago, ProDave said: Yes I believe the case length is overall length, how deep the hole in the door needs to be, and backset is distance fromt he door edge to the centre of the spindle. Ok fab thanks, this narrows my search down/ saves time. I think I'm all set, a good few in toolstation one should do it. Much obliged chaps, Zoot
