WWilts Posted November 25, 2022 Posted November 25, 2022 (edited) New build in progress. Extractor needs to be turned by 180 degrees to face the hob. Not a problem to turn it around, EXCEPT The fan plug (pic, circled red) projects out and would not squeeze into the very limited space available (drawer unit carcass wall limits the space) How to make the plug project less? Some kind of adaptor & extension? Fiddle with the plug? Other? Edited November 25, 2022 by WWilts
markc Posted November 25, 2022 Posted November 25, 2022 Remove the panel it’s fitted to and do away with it or put it inside the opening instead of outside. Watch out for bare terminals behind that could touch the metalwork 2
Radian Posted November 25, 2022 Posted November 25, 2022 How far is it away from actually fitting? The cable group going into the plug is overwrapped with heatshrink tubing. Might you be able to soften it enough to fold it over with a hairdryer or heat-gun? I'm not really understanding what space it doesn't fit into. 1
ProDave Posted November 25, 2022 Posted November 25, 2022 Sorry I am thick again I see the socket in your picture and the plug that has to go into it and see no reason it just won't plug in. Just what is in the way? 1
WWilts Posted November 25, 2022 Author Posted November 25, 2022 5 hours ago, Radian said: I'm not really understanding what space it doesn't fit into. 5 hours ago, ProDave said: Just what is in the way? The extractor unit in the pic needs to be turned by 180 degrees to face the opposite way. When that is done, the socket sits very near to a carcass panel. The carcass has drawers on the other side of that panel. So even cutting out the panel would not entirely solve the problem. The problem is that the plug projects out and would push up tight against the carcass panel. If it could be squeezed in at all. Therefore looking for some arrangement that can be squeezed into the limited space between the socket and the carcass panel.
dpmiller Posted November 25, 2022 Posted November 25, 2022 the socket is just clipped into the panel; remove the panel to see if you can unclip it and then probably enlarge the hole a little to let the socket come out through, then the plug and socket should be able to sit flat. Unless the socket is mounted on a pcb of course...
Radian Posted November 25, 2022 Posted November 25, 2022 38 minutes ago, dpmiller said: the socket is just clipped into the panel; remove the panel to see if you can unclip it and then probably enlarge the hole a little to let the socket come out through, then the plug and socket should be able to sit flat. Unless the socket is mounted on a pcb of course... Yes, sometimes those receptacles are chassis mounted - using plastic blades to secure them to the chassis. Worth a closer look.
WWilts Posted November 25, 2022 Author Posted November 25, 2022 (edited) 6 hours ago, ProDave said: Just what is in the way? The panel will be in the way, once the extractor is turned by 180 degrees to face the hob. The plug will have to project out less from the socket. Edited November 25, 2022 by WWilts
WWilts Posted November 25, 2022 Author Posted November 25, 2022 11 minutes ago, dpmiller said: Unless the socket is mounted on a pcb of course Afraid to fiddle with the socket mounting, for such reasons. (Just a layperson here, anyhow) Something to bend the plug would help. 5 hours ago, Radian said: hairdryer Perhaps
Radian Posted November 25, 2022 Posted November 25, 2022 1 minute ago, WWilts said: Afraid to fiddle with the socket mounting, for such reasons. (Just a layperson here, anyhow) You've got to show these things who's boss! Seriously, if the socket is the type I think it is, then the back of it will have a wiring loom going into crimped receptacles. There may be some slack in that loom to allow you to dismount the socket and lay it flat. Is the recessed plate holding the socket riveted or screwed to the chassis? 1
WWilts Posted November 25, 2022 Author Posted November 25, 2022 1 hour ago, Radian said: Is the recessed plate holding the socket riveted or screwed to the chassis? Will take a look in the daylight
WWilts Posted November 26, 2022 Author Posted November 26, 2022 18 hours ago, Radian said: Is the recessed plate holding the socket riveted or screwed to the chassis? Riveted
Radian Posted November 26, 2022 Posted November 26, 2022 Well I guess it all depends on how desperate you become. What I'm now wondering is if the body of the plug itself would have enough clearance? If you carefully slit the heat-shrink tubing, you'll find each individual wire goes into the plastic shell where it's terminated with a crimp connector. A bit like this: The heat-shrink is adding a great deal of bulk. I won't say unnescessary bulk - its there to keep stuff getting into the back of the connector which has probably got 240VAC on it, but as you can see, the individual wires would fold flat and with some electrical tape to cover it all up you might have enough clearance.
