Can you disassemble MVHR unit to transfer through loft hatch
Like the title says - can a unit like Zehnder Q350 be disassembled and re-assembled easily?
I'd like to install it in boarded loft space. Loft hatch is 700x700, unit is 850x720x570, I can't really make loft hatch bigger and I can't make a temporary hole in ceiling elsewhere due to joint spacing.
My only option is to disassemble it, move it to loft in parts and then reassemble.
Any ideas?
Edited by I N
Is there a stop bead around the hatch (like a door stop?)
You only need an extra 20mm.
Otherwise I would be removing the loft hatch surround and while doing it, probably enlarging the hole and enlarging at least one dimension.
Thanks its a good idea and if it was a just a case enlarging the loft hatch I'd do it tomorrow :-). Trouble is the loft hatch is off centre to roof space and there is a purlin just above it. Even if I can squeeze it through the hatch by width, it needs to be 500mm deep to clear purlin. So I need to somehow get it to 700x500 pieces to get it up there :-).
Its disassemble + reassemble (if thats even possible) or choose something different.
13 hours ago, Nickfromwales said:
My work here is done….
Thank you so much :-). This is perfect. I have actually asked CVC for a quote so I'll direct them to this unit.
I have been trying to find a unit that fits too - the only unit I could find was Vent Axia but they were really difficult with giving me a quote which made me a bit reluctant to use them.
