Can't up the flow on flow meter
Jymmm
Hi All,
I've always struggled to set the flow on the above flowmeters. I've only just noticed that they sit alot higher than the others on the black plastic threaded part. Is this why i can't increase the flow? How do i fix this?
How would i know the type to replace if i need to get another one
Thanks
That means they are fully open. If the flow rate won't increase, it's likely due to the pipe loops being longer than the others and the pump can't overcome the pressure loss. Make sure the valves on the return end of the manifold are open as well. What's your pump setup and what are the flow rates on the other loops? More than one manifold?
Edit, they seem to be about 3lp/min? That should be more than enough.
Edited by Conor
Thanks for the replies -  that makes sense.
Trying to increase the floor temperature in that room as its a few degs lower compared with the other loops. The pipe lengths are unknown to me unfortunantly and its the furthest room from the manifold/pump. I'll have to see what can be done with the pump speed.
Thinking about it backwards; In terms of efficency with a heatpump & buffer - Would it ever make sense to match the other loops to the worst performing loop? I.e adjust the other loops to give the same surface temps as the coldest floor surface making everything the same.
Which one(s) are you trying to increase?  they all look pretty good apart from the one on the right, which looks like it has some way to go if you want to increase it.
Be aware there is no "stop" on the adjustment and you can unscrew the flow meter completely, then you get wet. (you don't need to ask how i know)
